Rebuilding a mini starter? #66369
05/30/08 08:25 PM
05/30/08 08:25 PM
Tampa Florida
dc426 Offline OP
gotta keep'm separated
dc426  Offline OP
Tampa Florida
anyone try it as per the Mopar Muscle article? I have a couple that need rebuilt and would like to save a couple of bucks. Wondering how hard can it be?
DC
Re: Rebuilding a mini starter? [Re: dc426] #66370
05/30/08 09:22 PM
05/30/08 09:22 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Easier than the old ones. Mostly, the contacts in the solenoid wear out, causing the starter just to "click" when ya hit the key. Sometimes cleaning them help; other times we've brazed the contacts and disc up and resurfaced them. I've never had to actually replace one because it couldn't be fixed. FYI, they can be damaged by the old smack it with a hammer trick; it cracks the permanent magnet.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Rebuilding a mini starter? [Re: dc426] #66371
05/30/08 09:22 PM
05/30/08 09:22 PM
San Clemente, ca
enelson Offline
mopar addict
enelson  Offline
mopar addict
San Clemente, ca
Never saw the article, but I've done quite a few by replacing the contacts. I still have my personal one under the bench that got new contacts but I've yet to run it
Toyota sells them, and its funny they rebuild them all the time.
Wasn't too difficult. Hardest part on that rebuild was removing the right angle plug for the positive cable and starter signal, but that's not really part of a rebuild.
Eric
Re: Rebuilding a mini starter? [Re: dc426] #66372
05/30/08 09:56 PM
05/30/08 09:56 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
One of the easiest and most rewarding repairs you can do.I have easily done over a hundred of them from working at Honda and Toyota dealers over the last 23 years.I can get you the good Nippondenso OE contact kits with all new insulators and hardware.Just let me know which ones you need and send me a PM
Gus
64 Plymouth Savoy
Dana 60
Re: Rebuilding a mini starter? [Re: fourgearsavoy] #66373
05/31/08 07:34 AM
05/31/08 07:34 AM
Almost never any reason to go into a mini except replacing contacts.
Re: Rebuilding a mini starter? #66374
05/31/08 07:56 AM
05/31/08 07:56 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
looks like I'll be saving a few bucks on my next engine build, as I still have the stock mini that came off my Dakota, it worked but I was leary of using it since it had 100K miles on it. looks like about an hour or so and I can have the piece of mind of a brand new one!
**Photobucket sucks**
Re: Rebuilding a mini starter? [Re: dc426] #66375
05/31/08 08:16 AM
05/31/08 08:16 AM
morrisville, pa
skajm Offline
skajm  Offline
morrisville, pa
what is the part number for the toyota contacts????
joe
Re: Rebuilding a mini starter? [Re: skajm] #66376
05/31/08 01:01 PM
05/31/08 01:01 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
I think it was the latest issue of Mopar Muscle that just did a big article on rebuilding the mini starters with some good pics etc. I didn't read it but it looked to be pretty comprehensive.
Re: Rebuilding a mini starter? [Re: Classof70Chally] #66377
05/31/08 03:39 PM
05/31/08 03:39 PM
Tampa Florida
dc426 Offline OP
dc426  Offline OP
Tampa Florida
I just found this. Just about the same as the MM article, but the pics are better.
DC
http://www.tercelreference.com/articles/rebuild_starter/rebuild_starter.html
Re: Rebuilding a mini starter? [Re: skajm] #66378
06/02/08 07:25 PM
06/02/08 07:25 PM
joe
There are many different types, You'd be ahead to take old ones with you.
