96 dakota oil pressure dropping????? #66339
05/30/08 07:01 PM
05/30/08 07:01 PM
Monee IL
chicagotim2003 Offline OP
Monee IL
My friend has a 96 dakota.The oil pressure light comes on and the oil pressure needle drops.If he turns the engine off then on again it operates as normal.Would this be a problem with the oil pump or gauges?This occurs a few times a week.Thanks.
Re: 96 dakota oil pressure dropping????? [Re: chicagotim2003] #66340
05/31/08 01:05 AM
05/31/08 01:05 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Could be a plugged pickup screen, or if you're lucky a bad sender. You may want to put a test gauge on there to see if it really loses pressure.
Re: 96 dakota oil pressure dropping????? [Re: buildanother] #66341
05/31/08 05:46 AM
05/31/08 05:46 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
The gauge in my 2000 R/T does the same thing. It never drops low enough to turn the light on though. It's been doing it for 70,000 miles, so I have just accepted the gauge is wacky.
I guess if he wants to be sure he can plumb in a mechanical gauge and watch for awhile.
