727 tailshaft cracked in two again.
#663322
04/06/10 10:24 PM
04/06/10 10:24 PM
Posts: 502 North Texas
1AARCUDA
North Texas
I have about a 2" travel on my yoke that slips inside the tailshaft, Is that enough play to keep my driveshaft from hitting my tailshaft? How much play should I have?
1970 AAR CUDA
1970 Super Bee 383 Auto
1969 Super Bee 383 4Spd
1968 Satellite 500 Stroker
1986 Shelby GLHS
1970 Coronet 500 383 Auto
1996 Indy Pace Truck
1998 Dakota R/T 408 Stroker
Re: 727 tailshaft cracked in two again.
[Re: 1AARCUDA]
#663323
04/06/10 10:34 PM
04/06/10 10:34 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Is it more than 3/4" out from being bottomed... whats the rest of your set up... are you running front motor plate and mid plate with a solid trans mount... I have seen many tail shafts break from that set up... what rear suspension
[Re: 1AARCUDA]
#663325
04/06/10 11:03 PM
04/06/10 11:03 PM
1AARCUDA
North Texas
When everything is in place and my rear u joint is planted in my third member yoke without the u bolts connected, I can slide my shaft in the tail housing 2 inches til it hits the area behind the splines and bottoms out. I am running a 500 stroker with moroso solid motor mounts and stock 440 GTX leaf springs and a pinion snubber. Is that 2 inches to much play?
1970 AAR CUDA
1986 Shelby GLHS
[Re: WILD BILL]
#663331
04/06/10 11:29 PM
04/06/10 11:29 PM
MR_P_BODY
Are you checking the travel with the rear end at ride height or with the car jacked up with the axle hanging?
Very true... with that much I sure hope its hanging, shouldnt have more than 3/4" at curb height
[Re: MR_P_BODY]
#663335
04/07/10 09:17 AM
04/07/10 09:17 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I forget the author but its the one everyone uses
Carl Munroe
[Re: WILD BILL]
#663336
04/07/10 09:19 AM
04/07/10 09:19 AM
MR_P_BODY
Carl Munroe
Yeah... that be him... thanks Bill
[Re: 1AARCUDA]
#663337
04/07/10 10:48 AM
04/07/10 10:48 AM
1AARCUDA
North Texas
The car is on jackstands with the jacks on the axle tubes. taking the driveshaft to get 2" cut off new u joints and rebalance.
1970 AAR CUDA
1986 Shelby GLHS
[Re: 1AARCUDA]
#663338
04/07/10 10:59 AM
04/07/10 10:59 AM
Posts: 337 the netherlands
383duster
super street
super street
the netherlands
I think it is better too add 1" , cutting off 2" wil give you 4" endplay
[Re: 383duster]
#663340
04/07/10 02:43 PM
04/07/10 02:43 PM
Posts: 4,247 Newfoundland
codfish
Newfoundland
I hope he didn't leave yet.
codfish
[Re: 1AARCUDA]
#663341
04/07/10 02:56 PM
04/07/10 02:56 PM
1AARCUDA
North Texas
Yes I left and I did double check and had them remove one inch only, Also After I removed my cracked housing I noticed that my shaft has some movement maybe a 1/8 inch side to side, is that normal?
1970 AAR CUDA
1986 Shelby GLHS
