340 Heads, What's What
#66329
05/30/08 05:47 PM
05/30/08 05:47 PM
Posts: 3,378 KY USA
mopargem
KY USA
Hey folks I have a set of 587 casting heads w/1.88 intakes for my 340 engine that I plan on rebuilding back to basically stock 1971 specs. How do these heads compare to the 915 infamous "J" heads. Is ther really any diff other than some 915 heads have 2.02 intakes. Thanks for any input.
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
Re: 340 Heads, What's What
[Re: MoparforLife]
#66331
05/30/08 10:08 PM
05/30/08 10:08 PM
Posts: 3,378 KY USA
mopargem
KY USA
Thanks, your probably right that they will work fine since I'm not building a race car here.I'm not seeing any pollution pump holes on these heads like later model 360 heads. My 340 is a 1973 and the heads look to be original with the motor, this motor is in my 71 road runner and looks to have been with the car for many years now, but needs a rebuild. I just want it to perform as well as a stock 71 340 does. I know that I will need higher compression pistons. Any more opinions?
[Re: mopargem]
#66332
10/06/08 03:20 PM
10/06/08 03:20 PM
Posts: 31 Pennsylvania, USA
340propak
Pennsylvania, USA
Can anyone tell me what those small holes below the regular exhaust ports are for on the 78 360 heads, do they have to be filled with jb weld? can i do it with the motor already installed in the car? I just noticed those after putting on a set of 340 hi-po manifolds, the regular 360 manifolds covered the holes.
[Re: mopargem]
#66333
10/06/08 03:47 PM
10/06/08 03:47 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
They will run als well or better than the 915 2.02 heads till you start to spin in the 6000+ RPM range. The smaller valve will actually most times give you better low end. Too many blame the heads for the lower power output of the later 340 heads when in fact it was a combination of other things that did it, big thing being lowering the compression ratio big time.
