HI-6 Crane ignition box #663292
04/06/10 10:01 PM
04/06/10 10:01 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
BIG question...
with the ignition box, do I still need the 5 pin ECU along with it or not ?
Dan
Re: HI-6 Crane ignition box [Re: Wedgeman] #663293
04/06/10 10:36 PM
04/06/10 10:36 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
Nope, the directions are confusing but you don't need the 5 pin ECU, the ballast resistor can be tossed out also.
You just have to hook up the mag pickup wires to the dist, the coil wires go to the...coil, heavy wires to the battery, and the one that turns the box on goes to the MIF wire.
Re: HI-6 Crane ignition box [Re: Wedgeman] #663294
04/06/10 10:36 PM
04/06/10 10:36 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Nope...
Re: HI-6 Crane ignition box [Re: Lefty] #663295
04/07/10 08:38 AM
04/07/10 08:38 AM
Buffalo, MN
hydro Offline
super street
hydro  Offline
super street
Buffalo, MN
If it starts but runs terribly rough, reverse the polarity on the distributor wires. The instructions are not too clear on this and I found out the hard way. Easy fix though.
Re: HI-6 Crane ignition box [Re: hydro] #663296
04/07/10 06:02 PM
04/07/10 06:02 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
THe thing is.....I don't know wich wires to hook up to the distributor..
Dan
Re: HI-6 Crane ignition box [Re: Wedgeman] #663297
04/07/10 07:17 PM
04/07/10 07:17 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I had an HI-6, and IIRC, thw wiring was way similar to msd 6al, so there should be some diagram sources on internet somewhere....
Re: HI-6 Crane ignition box [Re: buildanother] #663298
04/08/10 09:44 AM
04/08/10 09:44 AM
Buffalo, MN
hydro Offline
super street
hydro  Offline
super street
Buffalo, MN
Here's what worked for me: (Mopar electronic ignition distributor, magnetic pickup output, year unknown)
From Crane Hi-6 wiring harness there is a twisted pair lead, connect violet (+) to grey on distributor, green (-) to black on distributor.
Re: HI-6 Crane ignition box [Re: hydro] #663299
04/08/10 09:11 PM
04/08/10 09:11 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Thanks Hydro..
I'll keep you informed
Dan
BTW....any noticable improvements ?
Re: HI-6 Crane ignition box [Re: Wedgeman] #663300
04/09/10 08:58 AM
04/09/10 08:58 AM
Buffalo, MN
hydro Offline
super street
hydro  Offline
super street
Buffalo, MN
Huge improvement in idle quality and seems to start a little better. Difficult to time due to multiple spark. Overall a very good modiication and it has worked well for me!
Re: HI-6 Crane ignition box [Re: buildanother] #663301
04/09/10 10:38 AM
04/09/10 10:38 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
What is wrong with this diagram.
http://cranecams.com/pdf/90006000a.pdf
I have never had a problem timing mine and use a dial back light and set total timing. I have not noticed a bit of difference in run quality or performance gain over my home recurved Mopar set up with a chrome box. IMO it was a bunch of money spent needlessly. Only thing that I gained was a rev limiter.
Re: HI-6 Crane ignition box [Re: MoparforLife] #663302
04/09/10 05:15 PM
04/09/10 05:15 PM
Buffalo, MN
hydro Offline
super street
hydro  Offline
super street
Buffalo, MN
What page are you questioning? What were you expecting as far as improvements in performance?
The Hi-6 box gives a multiple spark at lower RPM's then defaults to a single spark as the RPM increases. Noticeable improvements sould be pretty much limited to better starting and better ignition at idle/lower RPM. High speed operation will be pretty much the same as a standard ignition. At least that's what I noticed with my installation.
Re: HI-6 Crane ignition box [Re: hydro] #663303
04/16/10 07:14 PM
04/16/10 07:14 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Anyone else used the HI-6S ignition box ?
Dan
