what size tire for my 71 cuda? #66306
05/30/08 05:47 PM
05/30/08 05:47 PM
Chester Springs, PA
tored1971 Offline OP
Chester Springs, PA
Hi Guys,I am looking for some suggestions and pics of what tire you guys are running.
I am gonna use the factory 14" rallye wheels that came with the car when new.
Thanks, Phil
Re: what size tire for my 71 cuda? [Re: tored1971] #66307
05/30/08 10:58 PM
05/30/08 10:58 PM
Chester Springs, PA
Chester Springs, PA
Re: what size tire for my 71 cuda? [Re: tored1971] #66308
05/30/08 11:02 PM
05/30/08 11:02 PM
Kirkland, Washington
Pacnorthcuda Offline
I'm not up to speed on the 14" offerings except to say you're severely limiting yourself. Does any body make a 265-285 / 60 / 14????
Re: what size tire for my 71 cuda? [Re: Pacnorthcuda] #66309
05/31/08 04:23 AM
05/31/08 04:23 AM
808CUDA Offline
808CUDA  Offline
The largest street tire with raised whie lettering would be BFG 245/60/14, so that would be my choice. Anything narrower wouldn't look too good
Re: what size tire for my 71 cuda? [Re: 808CUDA] #66310
06/08/08 04:21 PM
06/08/08 04:21 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
245/60/14 will look small diameter wise.
Taller option would be 225/70/14 but these would be a bit more narrow.
Upgrade to 15 inch wheels
Re: what size tire for my 71 cuda? [Re: rss] #66311
06/08/08 04:59 PM
06/08/08 04:59 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
If you are planning to use the factory correct 14 X 5-1/2" "rallye wheels" -
The factory tire would've been F70-14, closest modern equivalent 215/70/14.
225/70/14s would work but are sometimes on the tall side (for an e-body) depending on your ride height (& getting tough to find).
235/60/14s (short) and/or 245/60/14s (wide if on front) are an option depending on your desired look, but I'd use the later 6" wide wheels.
Re: what size tire for my 71 cuda? [Re: 808CUDA] #66312
06/08/08 05:06 PM
06/08/08 05:06 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
275/60/14 are offered ,think it was a M/T, but won't work well at all with a 5.5 or even a 6 wide rim. I would stick to a 215 or 225 - 70
Re: my 71 cuda looks mean raked [Re: rrunner] #66313
06/08/08 05:41 PM
06/08/08 05:41 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
im running
14x7 225/60/14 frnt
15x8 265/50/15's rear
niether the tires nor wheels are made anymore...kinda sucks.
Re: my 71 cuda looks mean raked [Re: mark7171] #66314
06/08/08 09:42 PM
06/08/08 09:42 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
cooper makes repro's
