stumble on acceleration #66279
05/30/08 04:57 PM
05/30/08 04:57 PM
Rutherfordton NC
BarryBum Offline OP
Fruit Of The Loon
BarryBum  Offline OP
Fruit Of The Loon
Rutherfordton NC
what is the probable cause of a slight hesitation/stumble at takeoff? It does good at cruising, but at take off from a stand still it has a slight hesitation. I guess you need to know this, its a 1973 318, automatic, new plugs, plug wires and rebuilt carb.
Re: stumble on acceleration [Re: BarryBum] #66280
05/30/08 05:10 PM
05/30/08 05:10 PM
Andrewh Offline
Andrewh  Offline
really only 2 choices. Not enough fuel, or too much.
Depends on if it hesitates, or bogs.
Re: stumble on acceleration [Re: Andrewh] #66281
05/30/08 10:17 PM
05/30/08 10:17 PM
Warrenton, VA
65Coronet7165 Offline
Warrenton, VA
Well, I have a 440 Hi Po motor in my 67 Chrysler 300. It has in-line dual quads on a single plane manifold. At low speed and small throttle openings, there is a definate bog. Give the gas a good push and it goes away. Front carb is an Eddy Performer and the rear is the original Carter AFB.
Re: stumble on acceleration [Re: BarryBum] #66282
05/31/08 12:38 PM
05/31/08 12:38 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
I would guess the accelerator pump not adjusted properly. With the slightest opening of the throttle there should be a squirt of gas in the primary venturis. This should be immediate. If there is any delay in the gas squirting, there will be hesitation. Adjust the spring on the Holley carbs or linkage on other carb designs.
Ron
Re: stumble on acceleration [Re: BarryBum] #66283
05/31/08 12:51 PM
05/31/08 12:51 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
what kind of carb are you running on it?
