How hard is it to change the door pins #662430
04/06/10 03:11 PM
04/06/10 03:11 PM
ME
79machocharger Offline OP
ME
Can you change the door hinge pins on a duster while the door is still on or will I have to take the door off? I bought one of the repair kits on ebay with the bushings and new pin.
Re: How hard is it to change the door pins [Re: 79machocharger] #662431
04/06/10 03:43 PM
04/06/10 03:43 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
If you want to use the bushing (and you do) you will need to pull the door to drill the hinge.
