stroker numbers #662304
04/06/10 12:21 PM
04/06/10 12:21 PM
Sweden
K
kennetto Offline OP
kennetto  Offline OP
K
Sweden
yesterday we did a dynodrive on my new stroker here is the numbers.
block chenoweth block in a bag 440 0,30 over, deck height 0,013 bore 4,3500 stroke 4,150
440 source stroker kit rod lenght 6,7600 flat top pistons
heads edelbrock 84 cc,s gasket felpro 1009
compcam roller rockers
camshaft straighlines performance
lobe lift intake 0,360 exhaust 0,345
rocker ratio 1,5 1,5
valve lift 0,540 0,518
adv dur 294 309
dur@.050 244 256
lobe centerline 108,0 116,0
lobe separation 112
carbs holley six pack
ignition pertronix distrubutor and second strike box
exhaust tti 2" headers
result 540 hp 5500 rpm
torque 587 4400rpm
Re: stroker numbers [Re: kennetto] #662305
04/06/10 01:54 PM
04/06/10 01:54 PM
NY usa
540challenger Offline
NY usa
adv dur 294 309
[Email]dur@.050[/Email] 244 256
lobe separation 112
torque 587 4400rpm
nice numbers very small cam too for the cubes you have and a six pac too boot
Was there any head work done to the eddies or were they OOTB
Re: stroker numbers [Re: 540challenger] #662306
04/06/10 02:05 PM
04/06/10 02:05 PM
Sweden
K
kennetto Offline OP
kennetto  Offline OP
K
Sweden
just a little polish no porting
Re: stroker numbers [Re: kennetto] #662307
04/06/10 07:00 PM
04/06/10 07:00 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
We dynoed a 493 very similar to yours. There were two differences: the heads were CNC ported, and the Scott Brown cam was a little bigger. The corrected peak numbers were 580 hp, and 602 tq for that engine. Considering those two differences in the builds, comparatively, the numbers seem to make sense.
It should be great on the street and a joy to drive.
Re: stroker numbers [Re: kennetto] #662308
04/06/10 11:18 PM
04/06/10 11:18 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
The 493 sixpack I have dynoed a little higher, but it had ported heads and intake and a hydraulic roller. It was about the same lift though .554" or there abouts. With the smallish cam it peaked out at 5500 rpm, but pulls a bit past that.
Re: stroker numbers [Re: jbc426] #662309
04/10/10 03:47 AM
04/10/10 03:47 AM
Sweden
K
kennetto Offline OP
kennetto  Offline OP
K
Sweden
thanks for your input it seems like my numbers are o.k.i think it will be great with my 4 speed and 4:10 rear.
