School me on vacuums/power valves
#662231
04/06/10 09:10 AM
04/06/10 09:10 AM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
I've recently started to try and tune my 850 DP, and I have a few questions. I have a pretty lumpy cam (Comp's XE295HL) and my vacuum at idle (~850) is 6 in Hg. The power valve that I'm currently using is a 5.0, so this seems about right. My intake vacuum increases up to about 20 in Hg with increasing rpm (I've only tested this up to about 3000 rpm). From what I understand, the vacuum normally decreases after some point until it reaches 0 in Hg at WOT. I'm guessing that the power valve is supposed to open up once the vacuum dips below 5 in Hg(?). So the circuit that the power valve is part of operates at high rpm? Is this correct or am I way off? I apologize in advance for the rookie questions...
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: School me on vacuums/power valves
[Re: Alikazam]
#662234
04/06/10 11:47 PM
04/06/10 11:47 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Why not follow Holley's advice? They say divide your in gear idle vacuum in half: thats your power valve. I'd try their advice and go with a #4. (Those guys know a little about Holley carbs)
[Re: StealthWedge67]
#662235
04/07/10 09:03 AM
04/07/10 09:03 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
If you want to really know what the carb is "seeing" from the engine, get your hands on a long peice of hose and tape the gage to the windshield while you drive the car. You're really interested in how it changes around town at part throttle and light throttle. There is more to a PV selection than idle vacuum in gear. Holley has personally told me go 1/2 the idle vacuum in gear, and also go "a few numbers down from that idle vacuum reading in gear." Within a couple days of each other...lol.
[Re: moper]
#662236
04/07/10 09:40 AM
04/07/10 09:40 AM
1968RR
Thanks for all of the input. My local parts store has a limited selection of power valves, so I'll probably have to order one (despite claims to be "performance oriented" it doesn't seem like many of the chain stores actually carry any real performance parts, unless you count Flowmaster mufflers and cold air intakes ). I'm probably going to go with the 3.5" Hg valve...
