Re: Will a '66 B-Body K-Member fit in a '62?
[Re: studiocranium]
#662170
04/06/10 05:48 PM
04/06/10 05:48 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I've put several late K-members in '62 B bodies and it moves the motor back 1 5/8". This allows more fan/radiator clearance and allows the use of later B body headers and oil pans. 3-piece throttle pressure linkage clears the firewall OK, the only problem is the transmission mount.
Also you will need to do some sheetmetal "massaging" in the floor tunnel and the pinch weld where the tunnel meets the firewall needs to be hammered flat.
