Page 6 of 6 1 2 3 4 5 6
Re: My Super Bee Project [Re: ] #2413438
12/05/17 03:05 AM
12/05/17 03:05 AM
southern Idaho
moparcyco Offline OP
southern Idaho
Decided to go with a digital dash.
Re: My Super Bee Project [Re: moparcyco] #2413439
12/05/17 03:11 AM
12/05/17 03:11 AM
southern Idaho
southern Idaho
Also finally got the motor and transmission installed. Went with an American powertrain TKO 600 kit had to trim the floor a little more than I wanted but its in.
Re: My Super Bee Project [Re: moparcyco] #2413441
12/05/17 03:15 AM
12/05/17 03:15 AM
southern Idaho
southern Idaho
And with the motor in got to test fit this bad boy
Re: My Super Bee Project [Re: moparcyco] #2472092
03/26/18 12:59 AM
03/26/18 12:59 AM
southern Idaho
southern Idaho
Got headers in. To anyone doing a gen III Hemi the drivers side header is a giant PITA I hope I never have to service the starter.
Re: My Super Bee Project [Re: moparcyco] #2472094
03/26/18 01:03 AM
03/26/18 01:03 AM
southern Idaho
southern Idaho
This motor is from a 2004 Durango so I switched valve covers and coils to 06 up. Also had to have some blank fuel rails machined to work.
Re: My Super Bee Project [Re: moparcyco] #2472095
03/26/18 01:08 AM
03/26/18 01:08 AM
southern Idaho
southern Idaho
Went with a four core champion radiator. Since this car has a procharger in the way of the p/s reservoir had a friend make and weld a mount for a remote reservoir turned out sweet.
Re: My Super Bee Project [Re: moparcyco] #2472100
03/26/18 01:20 AM
03/26/18 01:20 AM
southern Idaho
southern Idaho
Since this car has boost needed a boost referenced fuel pressure regulator. made a bracket that sealed off the egr port and made a nice mount.
Re: My Super Bee Project [Re: moparcyco] #2472102
03/26/18 01:25 AM
03/26/18 01:25 AM
southern Idaho
southern Idaho
Running a Holley HP system on this car with Accufab throttle body. Got the harness in very easy, except I had to make a bracket for a gm 3 bar style map sensor for the boost.
Re: My Super Bee Project [Re: moparcyco] #2472151
03/26/18 06:38 AM
03/26/18 06:38 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Man, that's looking good!
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: My Super Bee Project [Re: moparcyco] #2479827
04/09/18 08:25 AM
04/09/18 08:25 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Looks like great work so far
Re: My Super Bee Project [Re: Morty426] #2599062
12/31/18 02:43 AM
12/31/18 02:43 AM
southern Idaho
southern Idaho
Ended up having to refabricate the throttle bracket to make everything work out.
That ended up saving my a$$ I took the intake off to make it easier to work with went to clean everything up when I was done and look what I found in my number 1 runner. freaking unbelievable brand new. I could not reach with my fingers nor was it visible. had to get camera just right.
Re: My Super Bee Project [Re: moparcyco] #2599066
12/31/18 02:50 AM
12/31/18 02:50 AM
southern Idaho
southern Idaho
Also got the fan assembly on the radiator. Due to the size of this radiator had to cut the corner off to make it clear the strut rod bushing on the passenger side.
And installed. over all looks good has decent clearance to the engine.
Re: My Super Bee Project [Re: moparcyco] #2599070
12/31/18 02:59 AM
12/31/18 02:59 AM
southern Idaho
southern Idaho
There is not a lot of choices on where to mount the ecm with the holley harness. pretty much the passenger side kick panel. I made a plate out of sheet aluminum to sandwich the panel worked out pretty well. it ended up mounting very solid. Of course its painted nice as well.
Re: My Super Bee Project [Re: moparcyco] #2599071
12/31/18 03:05 AM
12/31/18 03:05 AM
southern Idaho
southern Idaho
I really wanted a tilt column in this car so I ordered an Ididit column. ended up waiting almost four months to get it, very nice quality fit like a glove. You do have to modify the wire cover to work though. Also got the rest of the hydro boost plumbed bled the brakes and clutch.
Re: My Super Bee Project [Re: moparcyco] #2599075
12/31/18 03:14 AM
12/31/18 03:14 AM
southern Idaho
southern Idaho
And how it sits now got most of the engine bay wiring,plumbing, etc done.
I was able to drive it to this spot! felt good to hear it come to life. The front need to come up only a few turns on the torsion bar adjusters. stance is nice. now of to the body shop to install glass and finish the paint.
Re: My Super Bee Project [Re: moparcyco] #2599079
12/31/18 03:23 AM
12/31/18 03:23 AM
southern Idaho
southern Idaho
I also have been learning how to fix and restore trim. I did all the pieces on this car turned out killer. this is just one all of it looks this good. What do you guys think?
Re: My Super Bee Project [Re: moparcyco] #2599200
12/31/18 02:04 PM
12/31/18 02:04 PM
Superfreak
Superfreak
Looks awesome! Keep up the great work.
