need some alignment advice and guidance #661976
04/05/10 10:45 PM
04/05/10 10:45 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline OP
I am trying to set my alignment on my 40 dodge Squattie truck
here at home.
it has a dodge D50 chassis and the inside of the tires have been worn down pretty bad and they squeel on most turns.
so I have the front sheet metal off now and this front end uses shims to adj it, well both sides had about 3/16" of shims so I took them out and put it back together to move the top of the tires out.
well now I have it back on the ground and here is what I have.
I put a square on the driveway and set it up against the buldge of the tire and it touches at the bottom and on the pass side the square is 1/2" away from the upper buldge and
the driver side is 1/4" away at the top...
and if I measuere from the center to center of the thread it is 59" at the back of the tire and 59 5/8" at the front.
so I have a toe out issues.
does anyone know what I should have to be in the ball park???
I can't bring the top out any more, what could be done to get this better or is the top of the tire suppose to be in some Ron....
Re: need some alignment advice and guidance [Re: Mopar Ron] #661977
04/05/10 10:49 PM
04/05/10 10:49 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
http://www.moparts.org/Tech/Archive/susp/26.html Should get you in the ballpark Ron
Re: need some alignment advice and guidance [Re: Mopar Ron] #661978
04/05/10 11:13 PM
04/05/10 11:13 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Ron,
-Steve
Down to just a blue car now.
Re: need some alignment advice and guidance [Re: 68HemiB] #661979
04/05/10 11:15 PM
04/05/10 11:15 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Ron,
-Steve
Well sure...the local old-tyme alignment guy is the easy way out..
Speaking of ....you gonna be around tomorrow ?
Re: need some alignment advice and guidance [Re: 68HemiB] #661980
04/05/10 11:20 PM
04/05/10 11:20 PM
Ron,
-Steve
PM me your #
I'LL Pm you mine
Never mind I see you already PM'ed me, I'll call you. Ron..
Re: need some alignment advice and guidance [Re: OzHemi] #661981
04/05/10 11:50 PM
04/05/10 11:50 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Ron,
-Steve
The "old-tyme" guy will be up there.
Are you in Compton or making more shiny metal things for the anaroT?
