Stalling on my Transbrake ??? #661931
04/05/10 09:26 PM
04/05/10 09:26 PM
Sherman Texas
The Shocker Offline OP
Sherman Texas
I have a SB (mild) Dart drag car with a PG and a TransBrake .The convertor is suppose to be about 3500 stall .I usually leave at about 3000 droping the throttle as i release the button.I have had sum tell me that i should be sticking it on the mat and then drop the button.Will it hurt the convertor if the motor is bogging against it?Its a Neal Chance unit .I realise that traction may become an issue if i do this ,but will it hurt anything in the trans to let it bog when the convertor runs out of stall ?I have ran it up to 4000 and i didnt hear a bog at that point ,but i didnt leave that high either .It was just a test to see if it would bog .I do not have a 2 step box ...
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
Re: Stalling on my Transbrake ??? [Re: The Shocker] #661932
04/05/10 09:34 PM
04/05/10 09:34 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Why not use a two step, that way you can taylor your launch rpm where you want it and not fully against the converter.
Re: Stalling on my Transbrake ??? [Re: The Shocker] #661933
04/05/10 09:36 PM
04/05/10 09:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The engine will go up against the converter... wont
hurt anything but dont think you can keep it there
for prolonged periods of time... it builds heat....
I go up against the conv on every pass(5600 rpm)
And yes if you are going to the floor as you let go
of the button you are NOT making the torque for coming
off the line.... put a chip in the MSD 2 step and go
to the floor and let the rev limiter take care of the
RPM
Re: Stalling on my Transbrake ??? [Re: dartman366] #661934
04/05/10 09:38 PM
04/05/10 09:38 PM
Sherman Texas
Sherman Texas
Alot of Nostalgia events i attend do not allow any electronics .A couple dont even allow the brake ,but the ones that do dont allow 2 steps or any electronics ...
Re: Stalling on my Transbrake ??? [Re: The Shocker] #661935
04/05/10 09:41 PM
04/05/10 09:41 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I would not recomend going all the way up on the Conv. It could lay it over. I think doing that is what killed mine.
I would install a 2 step (3 step would be better) and chipping the luanch. That way you can mat the throttle and not hurt it
Re: Stalling on my Transbrake ??? [Re: The Shocker] #661936
04/05/10 09:45 PM
04/05/10 09:45 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
ok then do as Mike said, just don't sit on it very long,,won't hurt the converter but they heat up quick, I run a trans brake and I mat it between the top and second bulb, and will be on the two step for only a split second, but if you are running a .400 pro tree it's a little hard to do that.
Re: Stalling on my Transbrake ??? [Re: dartman366] #661937
04/05/10 09:51 PM
04/05/10 09:51 PM
Sherman Texas
Sherman Texas
You guys have been a big help several times with this car anwsering my questions,plus this time .I will try it next time out and see what happens .I just want to say thanks again ...
