holley carb question #661802
04/05/10 06:45 PM
04/05/10 06:45 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
How do you remove the venturis from the main body?
Re: holley carb question [Re: crowbait] #661803
04/06/10 12:47 AM
04/06/10 12:47 AM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
I believe they are pressed in, but I'm not 100% sure of that. Unless you have a race carb I don't think removal is common practice. I take it you mean the boosters (the bronze parts in the middle of each venturi), correct?
Re: holley carb question [Re: crowbait] #661804
04/06/10 12:54 AM
04/06/10 12:54 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
This is one of those,if you have to ask maybe you should not be messing with it. Unless your making a throttle body?
Re: holley carb question [Re: goldmember] #661805
04/06/10 08:45 PM
04/06/10 08:45 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
It appears to be pressed in towards the metering plate.I was wondering if anyone has sucessfully replaced one and had an operable carb when they were done. Its a holley six pack center carb,if it matters.
thanks
guys
Re: holley carb question [Re: crowbait] #661806
04/07/10 11:37 AM
04/07/10 11:37 AM
Locomotion Offline
Locomotion  Offline
I read that a special tool is required to press them back in and probably to remove them too. The tool may also flare the end on the opposite side to hold it in place.
Re: holley carb question [Re: crowbait] #661807
04/07/10 01:10 PM
04/07/10 01:10 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Send the carb to Ben @ PROMAX and have him fix it properly for you
Re: holley carb question [Re: roadhazard] #661808
04/07/10 05:18 PM
04/07/10 05:18 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I'm still back at why you would want to mess with the venturis of a 6-pak center 2 bbl...
Re: holley carb question [Re: crowbait] #661809
04/07/10 06:01 PM
04/07/10 06:01 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Pressed in. BLP makes tools for installing and checking level.
Re: holley carb question [Re: BSB67] #661810
04/07/10 10:18 PM
04/07/10 10:18 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
Well here is a picture of the damage.
Re: holley carb question [Re: crowbait] #661811
04/08/10 08:07 AM
04/08/10 08:07 AM
scratchnfotraction Offline
ouch!! did it go out the tail pipe?
thats gonna need repaired for sure
Re: holley carb question [Re: scratchnfotraction] #661812
04/08/10 10:00 PM
04/08/10 10:00 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
It looked like that when I got it.
