brake light #661567
04/05/10 12:38 PM
04/05/10 12:38 PM
Mountain Home, AR
Nate8077 Offline OP
Nate8077  Offline OP
Mountain Home, AR
I have a problem with my '69 Barracuda I believe to be a grounding issue, but do not know where to look. My brake lights and turn signals work fine while operating without the headlights on. When I turn the headlights on the left brake light goes out completly when applying the brakes and that same turn signal operates very slowly while the headlights are on.
'69 Barracuda 318
Re: brake light [Re: Nate8077] #661568
04/05/10 12:47 PM
04/05/10 12:47 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Left taillight socket-ground problem most likely.
Re: brake light [Re: buildanother] #661569
04/05/10 12:56 PM
04/05/10 12:56 PM
Mountain Home, AR
Nate8077 Offline OP
Nate8077  Offline OP
Mountain Home, AR
Thanks. What would be the best/easiest way to ground it? I am not real familiar with electrical repairs. I have some eyelets, some wire and some other wiring repair stuff.
'69 Barracuda 318
Re: brake light [Re: Nate8077] #661570
04/05/10 01:17 PM
04/05/10 01:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Just try removing the bulb and be sure it's clean in the socket and the bulbs metal base.Try a new bulb. Tighten up the tail light housing which is how it grounds.
Re: brake light [Re: stumpy] #661571
04/05/10 01:34 PM
04/05/10 01:34 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Make sure the bulb isnt in backwards also.Easy to get them in wrong.Rocky
Chrysler Firepower
