Re: Fuel Tank Vent
[Re: PossessedDuster]
#661529
04/05/10 04:46 PM
04/05/10 04:46 PM
Posts: 1,044 Slidell, La.
doctor_mopar
Slidell, La.
You can vent under the car, you just need the vent line to go up high first, before it is turned down. The factory ones I have seen, went up through the trunk over the axle area, up under the rear deck ( where speakers mount ), and then back through the axle area and out under the car.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Fuel Tank Vent
#661533
04/11/10 02:17 PM
04/11/10 02:17 PM
doctor_mopar
Slidell, La.
Route it high, and back down again. It works. You shouldn't need anything over the end.
