Re: Could the mounting cuased my pump to leak????
[Re: WILD BILL]
#661454
04/05/10 09:24 AM
04/05/10 09:24 AM
Posts: 1,880 USA
Ron Silva
USA
Dig out your instructions. I believe it has to be mounted upright.
I had mine mounted upside down once and they told me that is a NoNo.
SRT DEMON ONE SEAT
[Re: Ron Silva]
#661455
04/05/10 09:31 AM
04/05/10 09:31 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I found the inst on line last night and it does say mount it vertically. That's what prompted the ?
Having no inst from the start and reading the other thread I figured it was ok as all the pumps "look" the same
Now I'm wondering if anyone has pulled it off or if mounting it horizontaly is asking for trouble.
[Re: RC91]
#661457
04/05/10 12:58 PM
04/05/10 12:58 PM
WILD BILL
BROOK PARK, OH
I really don't want to cut the trunk floor and I'm not convinced I'ld have room for it even if I did. If I tried to mount it vertically under the floor it would hang way to low.
If no one has gotten away with mounting one sideways I might have to go the the Magnafuel pictured in the posted link
[Re: 1_WILD_RT]
#661459
04/05/10 01:13 PM
04/05/10 01:13 PM
WILD BILL
BROOK PARK, OH
cuased????
I take it your saying that IS the problem
[Re: WILD BILL]
#661460
04/05/10 02:48 PM
04/05/10 02:48 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Bill, I believe the Magnafuel Pumps are supposed to be mounted vertical as well....they are very similar in design as BG
Rickster
[Re: WILD BILL]
#661461
04/05/10 03:41 PM
04/05/10 03:41 PM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
Bill, I had to "clearance" the trunk floor when I went from a mallory 140 to the 250. Here's pics. Before (mallory 140)
After (mallory 250)
[Re: rickstershemi]
#661462
04/05/10 04:20 PM
04/05/10 04:20 PM
WILD BILL
BROOK PARK, OH
Rickster
I just sent a PM to the member who posted the pic of the pump mounted horizontaly to ask him if he has had any issues as a result.
I beleive Cab said his MF 300 instructions stated it could be mounted any which way.
[Re: TechAtBG]
#661467
04/06/10 05:50 PM
04/06/10 05:50 PM
Challenger 1
Cincinnati, Ohio
A couple of other things too, the 400 must have a -12 an feed line or it can cavitate and cause internal damage .
Great advise.
I can't believe all the filters I see before the pumps, can't help with cavitation.
Start with a clean fuel cell and lines, then strain your fuel before it goes in the cell and your pump will be happier and last longer without a inlet filter.
There be some guys that'll tell you #10 line is OK for the inlet because that's what they use.
Inlet size should always be larger than the outlet size on most all pumps.
[Re: Challenger 1]
#661468
04/06/10 09:20 PM
04/06/10 09:20 PM
Great advise.
sorry but a clean filter on the inlet size is recommended for keeping your pump working properly and not allowing any debris to run through the pump. Product engineering and magnafuel all sell their pumps with fuel filters before the pump.theres a reason for that. but you are correct always have a larger inlet line than the feed line.
[Re: TechAtBG]
#661470
04/07/10 09:32 AM
04/07/10 09:32 AM
WILD BILL
BROOK PARK, OH
I do have a filter prior to the pump.
New seals might show up today so I'm thinking what have I got to lose by trying again only this time making sure the seals aren't dry on start up.
[Re: TechAtBG]
#661471
04/07/10 10:00 AM
04/07/10 10:00 AM
Challenger 1
Cincinnati, Ohio
We recommend a filter prior to the pump as well but our BG5000 does not create any restriction .
You would correct though in some of what we have seen guys trying to run for filters though that only have 130-140gph flow and trying to use it before a 400gph pump. Doesn't work well in those case.
I'm a old school Kinsler customer and that's what they recomened years ago. I also run mechanical fuel pumps on blown engines, which would torch it's self with any cavition.
I've raced at least 5 different motors injected on alky and have never hurt a pump or motor because of leaness, never ran a filter before the pump. 15 years running so far, no inlet filters for me.
[Re: WILD BILL]
#661472
04/07/10 10:24 AM
04/07/10 10:24 AM
Challenger 1
Cincinnati, Ohio
cuased????
Spelling...
Why not go mechanical belt driven pump? Way better than leaky electrics that strain your electric system.
