440 Motor mounts #661386
04/05/10 07:55 AM
04/05/10 07:55 AM
Buffalo, NY U.S.A.
MrNormsTA Offline OP
Buffalo, NY U.S.A.
For some reason having a tough time finding O/E replacement mounts for my 69 440 build, wondering if anyone had a good source or part #, thanks.
Rick.
Re: 440 Motor mounts [Re: MrNormsTA] #661387
04/05/10 03:47 PM
04/05/10 03:47 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
My car has the crappy Korean made mounts. The only USA made ones I found were the Schemaker ones that are a poly mount of some sort. Think they are called "Magnum Mounts".
I hesitated to spend the money on them only because I thought it may transfer some vibrations I don't want on a strictly street cruising car. Of course the torque strap seems to do some of that, but I think the engine is secure enough with it to not need to bother changing the rubber mounts right now.
I want my fair share
Re: 440 Motor mounts [Re: MrNormsTA] #661388
04/05/10 10:46 PM
04/05/10 10:46 PM
Oh
His and Her 69's Offline
Oh
Rick are you talking the metal parts that bolt to the motor or the rubber mounts that bolt to the K member??
Let me know I may have some metal pieces.
David
Re: 440 Motor mounts [Re: His and Her 69's] #661389
04/06/10 08:08 AM
04/06/10 08:08 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
I also have a set of mounts I'm not using.
I switched to the spool mounts.
They were on my 69 440.
