ram 4x4 front axle u joint removal? #661302
04/05/10 12:14 AM
04/05/10 12:14 AM
PA
maxwedge1 Offline OP
PA
dont see any retaining clips holding the u joint?
do they just press out? what keeps them in place?
Re: ram 4x4 front axle u joint removal? [Re: maxwedge1] #661303
04/05/10 05:58 AM
04/05/10 05:58 AM
Jensen Beach, Florida
pressureangle Offline
The retaining clip is behind the yoke ears, nearer the u-joint center. Dig around with an old screwdriver, you'll find them. Squirt the whole deal down with WD40 or a good penetrating oil, you'll thank yourself later.
Why do I torture myself so?
Re: ram 4x4 front axle u joint removal? [Re: pressureangle] #661304
04/05/10 01:06 PM
04/05/10 01:06 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Mine are clicking on the front of my 96' 2500 4x4 Ram also. Looking at them they don't look like there is any easy way to do them. Is it possible to get them out & new ones in without taking the whole hub assy apart? I was trying the other day & was having a hard time just trying to get the retaining clips out.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: ram 4x4 front axle u joint removal? [Re: 6PKRTSE] #661305
04/05/10 02:08 PM
04/05/10 02:08 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
As far as I know you have to remove the hub, and them pop the axle shaft out. Usually when a U joint is worn out the ball joints are dead also, so it's a good time to replace those too.
This link may help:
http://dodgeforum.com/forum/dodge-cummins-diesel/196964-diy-ball-joint-replacement.html
This should be in the truck area
