Re: Seized Pistons, What to do?
[Re: moparman89]
#661251
04/05/10 09:10 PM
04/05/10 09:10 PM
Posts: 8,494 Candler,NC / Myrtle Beach, SC
JDMopar
I dragged a 400 out of a scrap metal yard for $8, and it was stuck. I laid the PB Blaster to it for a day or 2, then used a piece of 2x4 and a heavy hammer like AHY said. The shock from the whack on top of the old pistons will break it loose. You won't see it turn from the whack, but it breaks the rust bond.Do that to each piston. Then use a breaker bar and socket on the crank, along with more PB Blaster till you get it to spin freely.
