Copper head gaskets, sealing issues #660909
04/04/10 09:09 PM
04/04/10 09:09 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Last year I used the Summit .043 thick copper head gaskets. I used the Permatex 'Right Stuff' around the water holes, I remember someone here mentioning that it may not seal with the right stuff. Well, it didn't. The block has o-rings in it but no o-rings or receiver grooves in the heads. The Summit copper gaskets had a nice consistent ring around them from the o-rings in the block, but the right stuff sealer looked like it never hardened or sealed. Water would kinda lightly run down the sides of my block after a run down the track.
So should I try these Summit gaskets($80 a pair) again with a different sealer or just buy the SCE Titan copper gaskets that have the correct sealer around the water holes already?
The Titans are $127 a pair and require either the block or head to be o-ringed, it does not say they both have to be o-ringed.
The SCE Titans are out of my price range and don't require any o-rings since the o-rings are embedded in the gasket itself.
So does anyone run the regular Titans? Do they seal?
Re: Copper head gaskets, sealing issues [Re: ProSport] #660910
04/04/10 09:29 PM
04/04/10 09:29 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Bob,
What my brother did with his 588" in his Polara that was o-ringed was use the Permatex Ultra Copper in a spray can. He would spray on a half dozen coats or more of the stuff on each side, letting each coat tack up before spraying the next. Never had a leak problem, and this was with regular copper gaskets.
Re: Copper head gaskets, sealing issues [Re: ProSport] #660911
04/04/10 09:34 PM
04/04/10 09:34 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
aneal your old copper gaskets & re-use them again & try a different sealer. thats your cheapest option. i used std silicon on my copper gaskets, never had a leak with them but i did have a receiver groove. good copper gaskets can be re-used multiple times if you look after them. i even got 9 re-uses from cometics so i like the re-cycle plan.
Re: Copper head gaskets, sealing issues [Re: moparguy7074] #660912
04/04/10 09:34 PM
04/04/10 09:34 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
Bob,
that is a lot of spray silicone.
Bob i hope thing get fixed for you.
Re: Copper head gaskets, sealing issues [Re: moparguy7074] #660913
04/04/10 09:46 PM
04/04/10 09:46 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
Bob,
... thats what i did..i'm using the SCE Titans...i originally installed them dry, with fresh machine shop deck surfaces, and they leaked. ..ended up using a scotch bright to clean off the embossed o'ring around the water holes..then used the Permatex stuff...hasn't leaked since.
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
Re: Copper head gaskets, sealing issues [Re: racerAL] #660914
04/04/10 10:16 PM
04/04/10 10:16 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
So the Titans do not seal right out of the package??
I've heard mixed reports about the copper spray the last couple years. It's alot of work to tear this thing apart so I need to get this right. Don't have much spare time these days either. I'm also afraid to just try another sealer, what if it don't work.
Let's hear some more ideas.
I'm about to say screw it and just put some composition MP #4529455's on the motor. I used those on my 451 with no problems.
Re: Copper head gaskets, sealing issues [Re: ProSport] #660915
04/04/10 10:44 PM
04/04/10 10:44 PM
How smooth are the block deck and head surfaces? I have used the Titans with the teflon embossed(lined) on a new Hemi block that I didn't have decked that leaked like crazy sitting still on the dyno Took it apart and had the deck cut and smoothed up and no leaky reusing the same gaskets as before.Mopar must have used a cheeze grater to deck them blocks, I could feel the serations with my finger nails I put them on dry both times. SCE does recommend using spray on Hylomar on there non teflon lined copper head gaskest as well as the Titans, I think You could try some Aluminaseal stop leak first
Re: Copper head gaskets, sealing issues [Re: Cab_Burge] #660916
04/04/10 11:10 PM
04/04/10 11:10 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
Bob, I used Hylomar on my copper head gaskets and have had no leaks. You can get it just about anywhere too. Good luck.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: Copper head gaskets, sealing issues [Re: ProSport] #660917
04/04/10 11:22 PM
04/04/10 11:22 PM
Midwest
tony1966 Offline
tony1966  Offline
Midwest
I had similar issues. Orings in head, no groove in block. Water passages didn't want to seal, so i used 100% RTV silicone (like you get at Homedepot). Works great, but you have to watch where you put it. Not too thick and remember the shape of the passages in the block are not the same as the gasket and those are not the same shape as those in the head.
BTW, I tried the SCE gaskets, and they leaked. the thickness of the bead of sealer they put on really wasn't very thick and my heads are not that smooth. After one use the sealant was gone anyway.
Tony
Re: Copper head gaskets, sealing issues [Re: tony1966] #660918
04/04/10 11:37 PM
04/04/10 11:37 PM
Brisbane Australia
572B1 Online content
572B1  Online Content
Brisbane Australia
Hi Bob, We oring the block and don't have receiver grooves on the heads. I use threebond on the gaskets and make sure the gaskets are new,or anealed like rebel said. We have three different 440s over here streetdriven with the threebond and zero problems with water leakage.
ps I think some of you american guys call it yamabond.
Re: Copper head gaskets, sealing issues [Re: ProSport] #660919
04/05/10 07:53 AM
04/05/10 07:53 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
How tall does the o-ring stand from the deck? Copper or SS?You may get away with removing the o-rings all together. What do your surface finishes look like? Post some pics and details and maybe we can steer you into a perminent fix. The RightStuff shoulda' worked but, I use Mopar anerobic sealer PN 4318083. Some use coppercoat or holymer (spelling?)
Post deleted by Defbob [Re: ProSport] #660920
04/05/10 08:29 AM
04/05/10 08:29 AM
Re: Copper head gaskets, sealing issues #660921
04/05/10 09:17 AM
04/05/10 09:17 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
If you have an o-ringed block, and no receiver grooves in the heads, that's your problem right there. Because of the exposed wire, your heads will be lifted up from the deck. You need receiver grooves with o-rings.
Not completely true...That is why I asked how tall the o-ring stands. Higher end Fel-Pros have an o-ring integrated into the gasket (fire ring) and they don't critically bridge the head from the block.
Re: Copper head gaskets, sealing issues [Re: HardcoreB] #660922
04/05/10 12:48 PM
04/05/10 12:48 PM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
Agreed. My copper gasket does not leak with no receiver groves in the head. I believe the o-ring should stick up about .010".
Re: Copper head gaskets, sealing issues [Re: Shaker223] #660923
04/05/10 01:07 PM
04/05/10 01:07 PM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
My heads have no reciver grooves in them Bob. Have you tried Holomar (sp?) on them? I hear that stuff is great but expensive.
Steve
Re: Copper head gaskets, sealing issues [Re: 72chrgrally] #660924
04/05/10 03:51 PM
04/05/10 03:51 PM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
I used the Hylomar product!
Post deleted by Defbob [Re: HardcoreB] #660925
04/05/10 04:25 PM
04/05/10 04:25 PM
Re: Copper head gaskets, sealing issues #660926
04/05/10 06:02 PM
04/05/10 06:02 PM
PA
joez Offline
joez  Offline
PA
Hi Bob,
I had a similar problem years ago with an o-ringed block and no grooves in the heads. It was fine n/a, but when I sprayed it, it would leak. It would pressurize the cooling system and fill the overflow every time. I ended up putting an o-ring in the head just outsied the o-ring on the block to make a S-shaped squeeze on the gasket. A local racer recommended this. Never had a problem since. I used yamabond as a sealer before and after. I used to use moroso or pioneer ceramic seal too, because they usually would have small leaks like you describe when you first fill it with water.
Joe
Re: Copper head gaskets, sealing issues [Re: joez] #660927
04/08/10 07:33 PM
04/08/10 07:33 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
The man, the legend..................JoeZ! That sounds like a trick setup Joe, but I just want to find a decent gasket that I can throw on there and get running w/o having any machine work done.
My Summit gaskets probably would have been fine with some Moroso ceramic seal but since the motor is out for the oil pan I figured I'd do it right.
I'll measure my o-ring height this weekend but it doesn't stick out enough to cause problems, it left a very small indentation in the copper gaskets. I'll lay a flat edge across them this weekend and slide a feeler gauge in there.
SCE says either the heads or the block need to be o-ringed, not both, but both is probably better I would think.
I was all excited about the SCE Titans with the sealer and they are .032 thick which would help my compression since the piston is .016 in the hole. I wonder if I could run a bead of better sealer alongside their sealer , or just get the ones with no sealer. Or aneal mine. I'm still confused.
I'd just like to locate some MP 4529455's!!!
Re: Copper head gaskets, sealing issues [Re: ProSport] #660928
04/08/10 08:01 PM
04/08/10 08:01 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
This is what I have always put on my coppers...paint in on all 4 surfaces, not just around oil/water holes but the whole surface...torque down once, and never leaked an ounce of water or oil at 25 psi boost.
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
