04 Sebring convertible headlight switch #660884
04/04/10 07:53 PM
04/04/10 07:53 PM
Round Lake Beach, Illinoisy
Rhinodart Offline OP
Rhinotruck
Rhinotruck
The headlight switch on the column of my wife's 04 Sebring convertible is hard to put on and will not stay on sometimes. It looks like a real beatch to change and the stealership wants like $225 to install the $265 part! It is also on back order. Has anyone done this and where can I get the part cheaper?
JB Rhinehart, Realist
A-Body's RULE!
Re: 04 Sebring convertible headlight switch [Re: Rhinodart] #660885
04/04/10 09:19 PM
04/04/10 09:19 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
One option you may try is to get a hold of a local used car parts/scrap part yard, and see if you can find one that way. other than that it's a dealer item only, as far as i know. when you called your dealer to inquire about the part, did they ask you for your VIN#? if not they may have just priced you the most expensive one, there are 3 different one's it could be and the $265 is the most expensive. and as far as the labor..i would bet they are charging you 3hrs @ $75 an hr. to install the switch, which seems like alot, but i don't work with labor times very often to know for sure. i suggest you call a different dealer and see what kinda price quote you get from them. I couldn't verify the part being on back order, can do that tomorrow at work. i can tell you, as of Thurs. we had 1 in stock.
hope this helps
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
