Leaking fuel pump repair ????? #660781
04/04/10 06:44 PM
04/04/10 06:44 PM
BROOK PARK, OH
WILD BILL Offline OP
BROOK PARK, OH
With my BG 400 leaking I went to the O Ring ad on racing junk to check the price on the kit and noticed it says it also repairs MagnaFuel pumps.
Anyone try the MagnaFuel repair kit to fix their BG pump?
The problem I'm having is the seal for the motor shaft is leaking.
Re: Leaking fuel pump repair ????? [Re: WILD BILL] #660782
04/04/10 06:55 PM
04/04/10 06:55 PM
Ohio
Chad Bittle Offline
Chad Bittle  Offline
Ohio
Lots of people on Yellowbullet talking about using MagnaFuel seals to repair their BG stuff since BG doesn't make a repair kit.
Re: Leaking fuel pump repair ????? [Re: Chad Bittle] #660783
04/04/10 06:57 PM
04/04/10 06:57 PM
Ohio
Chad Bittle Offline
Chad Bittle  Offline
Ohio
or.....
http://www.product-engr.com/replacements.htm
PE 9000-3** Regulator diaphragm (HI-FLO 2 & 4 port) 25.85
BGP 400*** Seal/O-Ring Kit 22.30
BGP 280*** Seal/O-Ring Kit 21.00
NOTE **: Replacement part for 4-Port Barry Grant, Magna Flow, Superflow, Pro-Flow, and C.N.C. Performance Regulators
NOTE ***: Replacement seal kits for Barry Grant BG 280 and BG 400 Fuel Pumps
Re: Leaking fuel pump repair ????? [Re: WILD BILL] #660784
04/04/10 07:13 PM
04/04/10 07:13 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
well that sucks.be carefull with any static electricity.do you have a extinguisher?i dont know why it just came to mind.
Re: Leaking fuel pump repair ????? [Re: blownzoom440] #660785
04/04/10 07:40 PM
04/04/10 07:40 PM
BROOK PARK, OH
BROOK PARK, OH
I do actually
2 on the wall and one in the car
Nice to know the MF will work. Twice the price of the RJ ones but at least those I can get the same day. We'll see how long it takes to get the RJ seals but at least it looks like I'll still be able to make the spring warm up
Re: Leaking fuel pump repair ????? [Re: WILD BILL] #660786
04/04/10 07:50 PM
04/04/10 07:50 PM
New Braunfels, TX
416challenger Offline
New Braunfels, TX
I order my repair kit from the guy on Racing Junk. He shipped it out the same day, I received it about 2 days later. You will get a couple different seals and o rings in the kit. My pump was also leaking around the shaft and the new seal fixed it up.
Re: Leaking fuel pump repair ????? [Re: WILD BILL] #660787
04/04/10 07:51 PM
04/04/10 07:51 PM
ELYRIA,OH
ELYRIA,OH
you do work fast.
i wonder how long before mine leaks.
is your in the trunk or under the car?
Re: Leaking fuel pump repair ????? [Re: 416challenger] #660788
04/04/10 08:08 PM
04/04/10 08:08 PM
BROOK PARK, OH
BROOK PARK, OH
Thanks for that. We were just talking about if they would get here soon enough. Sounds like he doesn't mess around
MIke,
And here you thought I could only put in a trans fast
I've got to do all I can to keep ahead of the game
OH, and my pump is under the car
Re: Leaking fuel pump repair ????? [Re: WILD BILL] #660789
04/04/10 08:17 PM
04/04/10 08:17 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Yes the mana fuel and bg pumps take the same seals. Here is some info on several that I have repaired. You can buy the bearings and seals from any industrial company that sells these item. The seals are like 3.00 for 10 and the bearings are about 3.00 each. I can reseal and rebearing most pumps for 10.00. Here are some numbers.
Magna fuel Pump
NOK CU0034DO SEAL
JAPAN 629RS 1JK BOTTOM BRG.
THAILAND 608S NMB TOP BRG.
Barry Grant Pumps
Pump number 1
NOK CU0034DO SEAL
HAD R1-1438S BEARINGS
WE WERE SOLD BRGS. CHINA 9R6 CW
Pump Number 2
NOK CU0034DO SEAL
NTZ OR NT2 608LU BEARINGS TOP AND BOTTOM
Pump number 3
NOK CU0034DO SEAL
Re: Leaking fuel pump repair ????? [Re: NITROUSN] #660790
04/04/10 10:55 PM
04/04/10 10:55 PM
BROOK PARK, OH
BROOK PARK, OH
After a little more diggin I'm starting to wonder if my mounting it horizontally is part of the problem.
I saw this thread and figured it was OK but know I'm thinking perhaps the BG doesn't like it.
Anyone mounted a BG horizontaly and not had a problem?
