Leaking fuel pump repair ?????
#660781
04/04/10 05:44 PM
04/04/10 05:44 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
With my BG 400 leaking I went to the O Ring ad on racing junk to check the price on the kit and noticed it says it also repairs MagnaFuel pumps.
Anyone try the MagnaFuel repair kit to fix their BG pump?
The problem I'm having is the seal for the motor shaft is leaking. ![](/ubbthreads/images/graemlins/down.gif)
![](/ubbthreads/images/graemlins/smilie_help.gif)
Re: Leaking fuel pump repair ?????
[Re: Chad Bittle]
#660783
04/04/10 05:57 PM
04/04/10 05:57 PM
Posts: 687 Ohio
Chad Bittle
Ohio
or..... http://www.product-engr.com/replacements.htmPE 9000-3** Regulator diaphragm (HI-FLO 2 & 4 port) 25.85 BGP 400*** Seal/O-Ring Kit 22.30 BGP 280*** Seal/O-Ring Kit 21.00 NOTE **: Replacement part for 4-Port Barry Grant, Magna Flow, Superflow, Pro-Flow, and C.N.C. Performance Regulators NOTE ***: Replacement seal kits for Barry Grant BG 280 and BG 400 Fuel Pumps
[Re: blownzoom440]
#660785
04/04/10 06:40 PM
04/04/10 06:40 PM
WILD BILL
BROOK PARK, OH
do you have a extinguisher?
I do actually ![](/ubbthreads/images/graemlins/thumbs.gif)
2 on the wall and one in the car
Nice to know the MF will work. Twice the price of the RJ ones but at least those I can get the same day. We'll see how long it takes to get the RJ seals but at least it looks like I'll still be able to make the spring warm up
[Re: WILD BILL]
#660787
04/04/10 06:51 PM
04/04/10 06:51 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
you do work fast. ![](/ubbthreads/images/graemlins/2241092-prplchrgr.gif) i wonder how long before mine leaks. ![](/ubbthreads/images/graemlins/whistling.gif) is your in the trunk or under the car?
[Re: 416challenger]
#660788
04/04/10 07:08 PM
04/04/10 07:08 PM
WILD BILL
BROOK PARK, OH
I order my repair kit from the guy on Racing Junk. He shipped it out the same day, I received it about 2 days later. You will get a couple different seals and o rings in the kit. My pump was also leaking around the shaft and the new seal fixed it up.
Thanks for that. We were just talking about if they would get here soon enough. Sounds like he doesn't mess around ![](/ubbthreads/images/graemlins/thumbs.gif)
MIke,
And here you thought I could only put in a trans fast
I've got to do all I can to keep ahead of the game ![](/ubbthreads/images/graemlins/coffeetime.gif)
OH, and my pump is under the car ![](/ubbthreads/images/graemlins/wave.gif)
[Re: NITROUSN]
#660790
04/04/10 09:55 PM
04/04/10 09:55 PM
WILD BILL
BROOK PARK, OH
After a little more diggin I'm starting to wonder if my mounting it horizontally is part of the problem. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
I saw this thread and figured it was OK but know I'm thinking perhaps the BG doesn't like it.
Anyone mounted a BG horizontaly and not had a problem?
