Re: Holley pumps?
[Re: DaytonaTurbo]
#660502
04/05/10 05:00 PM
04/05/10 05:00 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
DT... lots of guys use mechanical pumps on blow through engines. Put boost pressure into the atmospheric port and it works just like your fuel pressure regulator. When boost goes up, fuel pressure goes up.
The Carter pumps seem to get the nod over the Holleys.
