Although all factory 318/340/360 small blocks are the same size and shape looking basically the same on the outside, you can tell them appart by looking at the assembly and casting numbers. Look at the front of the block under the drivers side head, there should be numbers that are stamped there that will id the engine, otherwise you'll have to crawl under the car to read the casting number on the side of the block. Blocks assembled after 1972 may appaear different in the black stamping area pictured, that's when the casting numbers are more helpful.
