Re: 727 OIL LOSS PLEASE HELP!
[Re: blown360]
#659894
04/03/10 01:51 PM
04/03/10 01:51 PM
[Re: blown360]
#659896
04/03/10 02:02 PM
04/03/10 02:02 PM
Weve drained the box so am I right in saying we should refill by 6.5 quartz to alloiw for the leftover oil in the verter? Does that sound about right?
your going to have fluid in the converter as well as the lines so no more than 6 quarts.
[Re: blown360]
#659898
04/03/10 02:08 PM
04/03/10 02:08 PM
Are all the deep alloy sumps the vsame cxapacity? this one measures approx 3.5" deep.
no, there are different size ones. put in 6 quarts, start it up get it warm in nuetral, pull out dipstick and it should read add 1 pint.
[Re: blown360]
#659904
04/03/10 05:05 PM
04/03/10 05:05 PM
goodluck to you guys over there!
[Re: blown360]
#659905
04/03/10 05:32 PM
04/03/10 05:32 PM
Posts: 25,949 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The FULL mark on the dipstick is 1/4" (6.3MM) above the ledge on the case that the tube inserts into.
[Re: John_Kunkel]
#659907
04/04/10 09:43 AM
04/04/10 09:43 AM
Posts: 16,930 NC
440Jim
NC
John, Are you referring to the top ledge shown in my attached picture (1-1/4 from pan gasket surface)?
I don't have a dipstick and tube except those installed in my cars to check.
[Re: moparmxz]
#659910
04/04/10 12:36 PM
04/04/10 12:36 PM
Posts: 1,880 USA
Ron Silva
USA
Just for reference, here is a setup I have here and I believe it is for a 904. I have several tubes and dip sticks and this shows it would in fact be above the boss the tube goes into. All my setups total variance is about 1/4" max mixing and matching tubes and sticks.
727 is probably similar if not the same. So 1/4" above the boss is most likely correct.
SRT DEMON ONE SEAT
