727 OIL LOSS PLEASE HELP! #659891
04/03/10 01:30 PM
04/03/10 01:30 PM
united kingdom
blown360 Offline OP
blown360  Offline OP
united kingdom
im away racing at the minute in sunny england with my buddies cuda racecar and we are having transmission problems. it is a freshly built 727 with transbrake, deep sump, 9 " converter all transbrake ready. the breather has been moved from the bell hoousing to the top of the gearbox. the problem we have is after every run there is oil spewing out of the breather. does any one have any ideas on what is causing this and how much oil capacity the gearbox would have ? it has a an aftermarket dipstick but im not sure if i trust it .. please help!
Re: 727 OIL LOSS PLEASE HELP! [Re: blown360] #659892
04/03/10 01:37 PM
04/03/10 01:37 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
well I hold the stick up on the outside of the tube and see just how far it would go in to the pan,That would give you some idea where the fluid level is and how the stick is marked,Fluid don't need to be above the pan rail for sure and could be lower
Re: 727 OIL LOSS PLEASE HELP! [Re: VernMotor] #659893
04/03/10 01:45 PM
04/03/10 01:45 PM
united kingdom
blown360 Offline OP
blown360  Offline OP
united kingdom
Ive just done that and its definetely above the pan rail!How much fluid approx should we have in this thing?
Re: 727 OIL LOSS PLEASE HELP! [Re: blown360] #659894
04/03/10 01:51 PM
04/03/10 01:51 PM
7 QUARTS maybe 7.5
Re: 727 OIL LOSS PLEASE HELP! #659895
04/03/10 01:55 PM
04/03/10 01:55 PM
united kingdom
blown360 Offline OP
blown360  Offline OP
united kingdom
Weve drained the box so am I right in saying we should refill by 6.5 quartz to alloiw for the leftover oil in the verter? Does that sound about right?
Re: 727 OIL LOSS PLEASE HELP! [Re: blown360] #659896
04/03/10 02:02 PM
04/03/10 02:02 PM
your going to have fluid in the converter as well as the lines so no more than 6 quarts.
Re: 727 OIL LOSS PLEASE HELP! #659897
04/03/10 02:06 PM
04/03/10 02:06 PM
united kingdom
blown360 Offline OP
blown360  Offline OP
united kingdom
Are all the deep alloy sumps the vsame cxapacity? this one measures approx 3.5" deep.
Re: 727 OIL LOSS PLEASE HELP! [Re: blown360] #659898
04/03/10 02:08 PM
04/03/10 02:08 PM
no, there are different size ones. put in 6 quarts, start it up get it warm in nuetral, pull out dipstick and it should read add 1 pint.
Re: 727 OIL LOSS PLEASE HELP! #659899
04/03/10 02:13 PM
04/03/10 02:13 PM
united kingdom
blown360 Offline OP
blown360  Offline OP
united kingdom
When we checked the dipstick just now its not long enough to go into the sump its sitting higher than the top of the pan so we cant really go by the dipstick as it would bring the oil level up past the pan rail. Its the one that was supplied by the box and from what I gather its too darn short. Does this sound right?
Re: 727 OIL LOSS PLEASE HELP! [Re: blown360] #659900
04/03/10 03:01 PM
04/03/10 03:01 PM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
I just took a look at a stock one and the fluid level full should be about at the top of the case were the dipstick goes in.
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: 727 OIL LOSS PLEASE HELP! [Re: moparmxz] #659901
04/03/10 03:44 PM
04/03/10 03:44 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i've been having the same problem with the breather so i've done the fluid level thing before. depends on your system how much fluid it has but when everything is hot the level should only be to the top of the pan! i have a hose coming off my tailshaft breather running up to the firewall where i've installed a mini k&n style filter, this seems to prevent the fluid spewing on the track & giving the track crew grief. good luck with racing the 'cuda
Re: 727 OIL LOSS PLEASE HELP! [Re: rebel] #659902
04/03/10 03:51 PM
04/03/10 03:51 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
With a deep pan there no reason to run the fluid level to the top of the case. Best to run it a little lower.stock pan only 1/2 " deep and we don't run them alot of rpm.No need in running the fluid up that high with a deep pan. with a race car.
Re: 727 OIL LOSS PLEASE HELP! [Re: VernMotor] #659903
04/03/10 05:02 PM
04/03/10 05:02 PM
united kingdom
blown360 Offline OP
blown360  Offline OP
united kingdom
Cheers for your help everyone! Much appreciated! Weve filled it just below the pan rail now and were gonna run it 2moro and hopefully well be sorted. Its a new engine/box/4link combo so were just setting it up this weekend. Ran a best of 10.3 today on a gentle pass misfiring so hopefully well hit the 9's over the next two days. We cant cure the miss until we get our new dizzy though grrrrrrr! If any of you guys know how to stop it raining too were open to suggestions! Cheers everyone!
Re: 727 OIL LOSS PLEASE HELP! [Re: blown360] #659904
04/03/10 05:05 PM
04/03/10 05:05 PM
goodluck to you guys over there!
Re: 727 OIL LOSS PLEASE HELP! [Re: blown360] #659905
04/03/10 05:32 PM
04/03/10 05:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The FULL mark on the dipstick is 1/4" (6.3MM) above the ledge on the case that the tube inserts into.
Re: 727 OIL LOSS PLEASE HELP! [Re: John_Kunkel] #659906
04/04/10 07:16 AM
04/04/10 07:16 AM
united kingdom
blown360 Offline OP
blown360  Offline OP
united kingdom
Thanks guys for your help! Weve set the level just below the pan rail so hopefully it'll find its own level after a couple of passes. Hoping to break the nines this weekend but its a struggle with our poorly dizzy just hope our new one turns up before the next meeting. Keep you all posted as the weekend goes on!
Re: 727 OIL LOSS PLEASE HELP! [Re: John_Kunkel] #659907
04/04/10 09:43 AM
04/04/10 09:43 AM
NC
440Jim Offline
440Jim  Offline
NC
John,
Are you referring to the top ledge shown in my attached picture (1-1/4 from pan gasket surface)?
I don't have a dipstick and tube except those installed in my cars to check.
Re: 727 OIL LOSS PLEASE HELP! [Re: 440Jim] #659908
04/04/10 10:06 AM
04/04/10 10:06 AM
NC
440Jim Offline
440Jim  Offline
NC
Here is a related question.
Why does the fluid level need to be submerging the valve body? Does the valve body aerate the fluid if the level is below that? Such as at high rpm and shifting, not driving around the pits. Maybe the servos aerating the fluid if their bottom is not submerged (normal leakage)?
The reason I ask is that I notice my race trans has issues if the fluid gets a little low. And it has a super deep pan with a 2" filter extension (with o-ring seal against the valve body). So air isn't getting in the filter.
Re: 727 OIL LOSS PLEASE HELP! [Re: 440Jim] #659909
04/04/10 10:31 AM
04/04/10 10:31 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
I,ve experienced the same thing, the level needs to be full or my trans shifts funky.I always just assumed when in use the level goes down from fluid pumping fast and not returning to the pan fast enough.
Re: 727 OIL LOSS PLEASE HELP! [Re: moparmxz] #659910
04/04/10 12:36 PM
04/04/10 12:36 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
Just for reference, here is a setup I have here and I believe it is for a 904. I have several tubes and dip sticks and this shows it would in fact be above the boss the tube goes into. All my setups total variance is about 1/4" max mixing and matching tubes and sticks.
727 is probably similar if not the same. So 1/4" above the boss is most likely correct.
SRT DEMON ONE SEAT
