tips for getting Poly strut bushings in K frame? #659732
04/03/10 11:03 AM
04/03/10 11:03 AM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
getting front end together on Duster, I have the 1 piece mushroom shaped poly strut rod bushings. So far I have them on the rod, with the washers, inserted through k frame and the outter washer and nut on, but shooting WD on the bushing to help it though while i pry on the outter washer to tug it though, about half way it it doesn't budge anymore. also tried removing rod and popped bushing in thinking it may need to colapse where the rod would be to fit..no dice either.
Any suggestions?
EDIT, it hit me, I was able to take the Ball joint socket, the 2 strut washers, a long headbolt, and a nut, and press it on with that and the poly lube.
thanks for reading.
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: tips for getting Poly strut bushings in K frame? [Re: MonGoo$e] #659733
04/03/10 08:59 PM
04/03/10 08:59 PM
NY NY
3
340duster340 Offline
NY NY
what brand are the bushings? the ones i have are two piece. i got them on jegs for dirt cheap.
at least you were able to get them in.
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: tips for getting Poly strut bushings in K frame? [Re: 340duster340] #659734
04/03/10 09:46 PM
04/03/10 09:46 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
I believe they are the Just Suspensions (yellow box that displays the red bushings)
in the past when I got rubber ones at the parts house they were shaped just like these.
Re: tips for getting Poly strut bushings in K frame? [Re: MonGoo$e] #659735
04/03/10 10:41 PM
04/03/10 10:41 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Put the bushing in the K member first, then put the strut rod in the bushing, otherwise forget it and get the two pice units.
Don't be the exception.
Re: tips for getting Poly strut bushings in K frame? [Re: Supercuda] #659736
04/03/10 11:10 PM
04/03/10 11:10 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
notice that I got them in, thanks.
