I have a 572 aluminum HEMI w/World Products aluminum block and the ALTERKTION subframe set-up for my 73 Challenger. I'm hearing that the Milodon H/V Oil Pump w/enternal lines will interfere with the driver's side ENGINE MOUNT.
I'm hoping there's a way to use the Milodon pump even though I could use the OEM Mopar hemi pump.
I was also told that it's the pump cover that may interfere with the engine mount and not the pump itself. HELP! What can I do?
Thanks, Scott in Michigan
