small block help needed #659534
04/03/10 03:41 AM
04/03/10 03:41 AM
nc
E
earthmover Offline OP
E
nc
well guys i went out to tnt tonight and it was ok but could be better...1st here is the combo
340 bored 30
stock stroke crank with h beams and dome tops
j heads with clean up 240/140@500
comp cam 244/252@50 solid cam 520/540 with 1.5 roller rockers
x-cal intake port match to head with 1" open spacer,950hp 82/88jet 6.5 pv fr/no pv bk pick cam
36 timing locked out with a open spacer
727 with 9.5 verta 5000 that flash at 4000
with 4.57 gears and 28/10.5 slick m/t@13psi.
electric water pump drive and alum radi.
best last yr of 7.54@89.?? and 1.67'/with 111 fuel
with the 950 the car will bust up at the end of the track (1/8) right at the end light at finish.
so next run
new best of a .095 rea.
1.663 60'
4.761 330
7.440 1/8@87.762
tire psi i thought was 12 but was realy 7
next run the computer was down and i think was my best but on time ...([Edited by Moparts - Family Friendly Site - Keep it clean])
then computer went down(i thought was the best time)-----------------------------------
next time i made some changes/100oct. fuel
went to a 750 aed/ho with a 4 hole spacer
with i thought was 11psi but was 16 and went
-.067 rea.
4.839 /330
7.534 1/8@90.005
10psi
rea. .006
4.831 330
8.435@58.772
next run was 13 psi
rea. -.127
4.894 330
7.607@85.741
now my car went the fastest with best time with the 950hp and (i think 17psi in the tire)
but my best mph was with the 750aed/ho at 90.005mph
what makes the 950 bust up at the end of the track???sounds like the valve spring going bad...but then i put the 750 on and run out the back door....
now with the 950 it seems that the carb would spin worst then go..(my buddy said he can hear the car spinning the wheel he was on the track with me)but the 750 did not spin as bad or leave as hard but ran out the back door....what should i do work on the 950 or get a 750???? the verta would flash 4000 at about 10mph from a roll, i did get to check that....at 1st i thought i needed some new springs but now i am lost so i thought i would ask the pro's.....i know the car has more in it but where should i start with it????so come on small block guys help me out.. i learned that me tire press. gauge was so far off like 5psi then i change that psi after the 2nd time pass
so do you guys think carb is to big or just need to work on it???
Re: small block help needed [Re: earthmover] #659535
04/03/10 08:12 AM
04/03/10 08:12 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
The only way I can see a carb causing it to " bust up " would be if the fuel pump wasn't keeping up with things.
Do you have a fuel pressure gauge ?
Minimum 3/8ths fuel line ?
Clean pick up in the tank ?
With the parts described , I would be expecting a little bit more than you are getting.
I'd probably start looking at fuel delivery for the problem.
Re: small block help needed [Re: tubtar] #659536
04/03/10 09:16 AM
04/03/10 09:16 AM
nc
E
E
nc
my fuel system is 1/2 alum. line from 8gal. cell all to holley blue pump then to holley reg. and a fuel filter then to the carb inlet line..the press. gauge set on 7.5 when i go higher it seems to be realy rich but now only thing i changed was the carb and spacer and like i said with the 750 aed/ho it pulls all the way though with no problem,but with the 950hp it will pull just til the 1/8 mark and stat to bust up like it needs new springs or something...i just dont know where to start......but i had my best time with the 950hp..also with the 950 he buddy that was at the line with me said he could hear the car blow the tire off when i leave.... i have a vid. of the car leaveing on the 1st pass and then the 3rd ill try to post not sure if i can but i need to get on this fuel deal...i know the car has way more in it if i work it out.....even had chevy guys talking about how good it should run if i get it right. so any help or ideas would be great
Re: small block help needed [Re: earthmover] #659537
04/03/10 09:23 AM
04/03/10 09:23 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
That covers the fuel system.........I think.
It sounds like a delivery problem still based on what you describe.
Bucket test after the filter ?
Re: small block help needed [Re: tubtar] #659538
04/03/10 09:34 AM
04/03/10 09:34 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
My personal opinion is that it probably doesn't have enough cubes or cam to want the 950 on a 344" motor. I'd work on the 750...
Re: small block help needed [Re: earthmover] #659539
04/03/10 09:38 AM
04/03/10 09:38 AM
Hemiroid Offline
Hemiroid  Offline
I didn't see you mention jetting up the 950? If you didn't attempt to play with the jetting I would start there.
Re: small block help needed [Re: Hemiroid] #659540
04/03/10 09:51 AM
04/03/10 09:51 AM
W. Kentucky
justinp61 Online content
justinp61  Online Content
W. Kentucky
Does the 950 have jet extensions in the rear? IMHO the 950 is to much carb. My pump gas 344 ran 7.30s in the heat and low 7.20s in good air with the same intake you have, a 750 and a hydraulic cam that was 237/242 @ .050. The car was 3300# with a 4400 rpm converter and 4.30 gears. The carb was a Quick Fuel Q-750, power valve in the front only, the jets were 72f/78r. The heads were ported Edelbrocks.
Re: small block help needed [Re: justinp61] #659541
04/03/10 01:42 PM
04/03/10 01:42 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Ya got any rpm #s crossing the line?
Re: small block help needed [Re: emarine01] #659542
04/03/10 02:01 PM
04/03/10 02:01 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
my 341" (318 based) with e heads and bowl ported eddies works really well with the 830 annular and stock 78 jets, we'll find out how well once I get some more tire up under it!
WIZE
In Car:
Re: small block help needed [Re: Streetwize] #659543
04/03/10 11:16 PM
04/03/10 11:16 PM
nc
E
E
nc
i cross the line at 6500 and when i was on the return road i flash the verta it goes to 4000 its a 9.5 5000.
Re: small block help needed [Re: earthmover] #659544
04/04/10 01:03 AM
04/04/10 01:03 AM
Bend, Oregon
67cuda340 Offline
super street
67cuda340  Offline
super street
Bend, Oregon
My X head, solid cam 360 runs 7.8's with a
FBO prepped 650 mighty demon. My engine is
tired and needs to be rebuilt. I run a
mechanical holley strip fuel pump.
Setup the 750 and run it.
1973 Dodge Dart Sport 360 Drag radials 12.30 1/4 mile 7.82 1/8 mile
Re: small block help needed [Re: 67cuda340] #659545
04/04/10 01:25 AM
04/04/10 01:25 AM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
That 950 probanly needs to be rejetted, i had that same similar problem once.
Re: small block help needed [Re: Cheatham] #659546
04/04/10 09:36 AM
04/04/10 09:36 AM
nc
E
E
nc
yea it easter sunday and now i have to work on the car today..hahaha so ill be looking over things checking how long it takes to fill 1 gal. a few other things i guess....ill keep you posted..
Re: small block help needed [Re: earthmover] #659547
04/04/10 10:06 AM
04/04/10 10:06 AM
Tennessee
727builder Offline
727builder  Offline
Tennessee
950 is too big for that combo. Tune on your 750
Re: small block help needed [Re: 727builder] #659548
04/04/10 10:13 AM
04/04/10 10:13 AM
nc
E
E
nc
hay 727builder how about a run down on that 360 and set up you have in your post if you dont mind runs really good ....
Re: small block help needed [Re: earthmover] #659549
04/04/10 10:15 AM
04/04/10 10:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The 950 isnt too big.... might be slow on the hit
but the engine will take what it wants... I would
look at tuning the 950 which I guess you didnt...
you said it was spinning more with the 950 more
than the 750.... tune the suspension after you get
the carb figured out.... JMO
Re: small block help needed [Re: MR_P_BODY] #659550
04/04/10 10:24 AM
04/04/10 10:24 AM
Down South
DaKuda Offline
DaKuda  Offline
Down South
My Cuda with .030 340, stock rods and crank. TRW 12:1 pistons and a 750 race carb would go 1.42 60ft and 7.00 - 7.07 depending on the heat. With a dual plane Edelbrock AirGap...
Re: small block help needed [Re: earthmover] #659551
04/04/10 11:52 AM
04/04/10 11:52 AM
Tennessee
727builder Offline
727builder  Offline
Tennessee
Nothing high dollar. It's a .30 over 360 with stock crank turned 10/10, Ross 12.5 pistons, Eagle H-beams rods, The 585 Comp solid lift cam, Home ported J-heads with 2.02/1.60 valves, Victor jr intake with 750 holley dp, 1.5 rockers.
Re: small block help needed [Re: 727builder] #659552
04/04/10 03:15 PM
04/04/10 03:15 PM
nc
E
E
nc
yea thanks mr.p i think it will take the carb aswell just need to fig. out what it likes . i have thougfht about a air gap but this car is more track (going that way anyhow) than street...i plan to put a cage in it this yr cause my son is going to take the seat with my shoulder surgery i have a hard time in it right now and my doctor told me 2 weeks ago i am going to need 1 more this yr. to replace my right shoulder...plus i can take a 10th off with him his more than a 100 pounds lighter ...so i think i my set up the intake to something more race later when i take the heads off and send them out to be worked over ...hay 727 thats a great combo you have thereand seems to be working very well. i think a set up in cam would not hurt this thing either since with the lash and all the intake should be under 500 and just over 500 on ex. with 1.5 rollers so i plan to tighten the lash after i get the fuel worked out to see if it help or hurt it ....hope to have the 8"verta soon....... 727 if you dont mind me asking again what does your heads flow and at what lift...mines only go 240/140@500 so i know i need to work them some
Re: small block help needed [Re: earthmover] #659553
04/05/10 01:05 PM
04/05/10 01:05 PM
nc
E
E
nc
