Which crankshaft socket? #659418
04/02/10 10:19 PM
04/02/10 10:19 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Which one will fit a big block Mopar? I want to use it for holding a cam degree wheel on the crank.
Here's the choices.
Re: Which crankshaft socket? [Re: ProSport] #659419
04/02/10 10:30 PM
04/02/10 10:30 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I have this one works great
http://chucker54.stores.yahoo.net/crtusowidewh.html
so it's this one
http://www.summitracing.com/parts/CCA-4799/
I taped a couple more set screws either side of the small keyway (mopar one)
