cast crank 440 balancer problem...help! #65910
05/29/08 10:01 PM
05/29/08 10:01 PM
Salem, OR USA
U
uh60lbhawk Offline OP
U
Salem, OR USA
I'm building a 440 for a 69 charger. Firstly, no, I don't race. My car will be a cruiser, driven mostly for fun or to car shows/cruise-ins.
That said, I bought this engine used, and the person I bought it from did the heads for me (452 heads). He also ahd the machine work done. If I remember correctly (it's been a while) he sai dit was a 1974 engine. During the machining, there was a crack/bubble in one of the cylinders, so he gave me a different block, from a '72 as far as I know, and had the machine work done on it.
It's bored 40, has kb hypereutectic pistons. The cast crank is ground 10. I bought the sepcial flex plate to use the non weighted torque convertor. I have a 727-B torqueflite transmission.
I put a mopar performance aluminum water pump housing on, and plan on using a flex fan with a shroud. I used the stock, low-rise intake manifold, from my other 440.
This is the first engine of any kind I have ever built, so I've been going slow and trying to make sure everything is right.
When I went to put the harmonic balancer on, it won't go in far enough. It bottoms out against the timing sprocket with about a 1/2 inch to go. I checked online, but cannot find another balancer that looks like the one I have, which leads me to believe I have the wrong one, yikes!
Here are some pictures of the one I have. Any help or suggestions will be greatly appreciated.
P.S.: Body work is way too expensive!!!!!!!!!!
Re: cast crank 440 balancer problem...help! [Re: uh60lbhawk] #65911
05/29/08 10:44 PM
05/29/08 10:44 PM
moparmedic Offline
moparmedic  Offline
Clint,
this is from the tech archives. Maybe it will help.
http://www.moparts.org/Tech/Archive/bb/22.html
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
Re: cast crank 440 balancer problem...help! [Re: moparmedic] #65912
05/29/08 10:58 PM
05/29/08 10:58 PM
Salem, OR USA
U
U
Salem, OR USA
Thanks. It's doesn't match any of those photos, but from the last picture, I'd say the balancer I have is for a small block engine.
That sucks. Anyone know where can I buy the right one for less than a small fortune?
Re: cast crank 440 balancer problem...help! [Re: uh60lbhawk] #65913
05/29/08 11:19 PM
05/29/08 11:19 PM
Btween a rock and a hard place
moparlulu Offline
moparlulu  Offline
I'll tell you what if you pay for the shipping. I'll give you one off a 400. It shouldnt cost you too much to ship, I'm in southern Idaho.
Re: cast crank 440 balancer problem...help! [Re: moparlulu] #65914
05/29/08 11:21 PM
05/29/08 11:21 PM
moparmedic Offline
moparmedic  Offline
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
Re: cast crank 440 balancer problem...help! [Re: moparmedic] #65915
05/29/08 11:46 PM
05/29/08 11:46 PM
Salem, OR USA
U
U
Salem, OR USA
Thanks, moparmedic, I put in a bid on the one on e-bay. It only has a couple days left.
Moparlulu, if I don't win the auction, I might take the 400 one. I assume it's interchangeable with the 440 cast cracnk? (I'm still learning this stuff)
Thanks again for the info and help.
Re: cast crank 440 balancer problem...help! [Re: uh60lbhawk] #65916
05/30/08 01:30 AM
05/30/08 01:30 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Looks like you have a 360 balancer. You need the one that says "440 cast crank only" on it. 400 balancer won't work right. I have a rebuilt one. PM me if your interested.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: cast crank 440 balancer problem...help! [Re: moparmarks] #65917
05/30/08 09:26 AM
05/30/08 09:26 AM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Your's is a 360 balancer, & the counterweight on a 400 unit is thinner than on a 440 piece.
Edit: I just went out & looked at a 400 balancer I have, & the whole thing is thinner than the 440 balancer.
Re: cast crank 440 balancer problem...help! [Re: vdriver] #65918
05/30/08 09:35 AM
05/30/08 09:35 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
heres something to ponder ...
i'm not 100% sure of this but isn't the balancer installed on the crank when balancing and external balance engine ? if this is the case and that balancer was used then you are going to throw the balance the engine off .
Re: cast crank 440 balancer problem...help! [Re: JohnRR] #65919
05/30/08 03:51 PM
05/30/08 03:51 PM
Salem, OR USA
U
U
Salem, OR USA
Yeah, I thought of that too. I'm going to ask the guy who balanced it if it was balanced with the the flex plate and the balancer, or jsut the flex plate. If he had the balancer on when it was balanced, I'll probably have to pull the crank back out and have it re-balanced.
What a pain in the butt! At least it's getting fixed before I fire it up.
Re: cast crank 440 balancer problem...help! [Re: uh60lbhawk] #65920
05/30/08 04:22 PM
05/30/08 04:22 PM
eganville ont
440beep Offline
440beep  Offline
eganville ont
the one you need
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: cast crank 440 balancer problem...help! [Re: 440beep] #65921
05/30/08 04:46 PM
05/30/08 04:46 PM
dogdays Offline
dogdays  Offline
EVEN THOUGH the 440 cast crank and 400 cast crank balancers are marked differently they have the SAME amount of imbalance. I firmly believe that they can be interchanged. You could look it up.
R.
