big block oil pump set up for a cooler?where?? #659153
04/02/10 05:50 PM
04/02/10 05:50 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
iv been looking for a oil pump for the hemi that i can run a oil cooler on (alum rods on street) and im having no luck
i have a oil pump that came with the motor but i dont know anything about it as it was just bolted on to keep trash out
the motor is a alum rod and will be drove on the street (some) and need to run a cooler to keep oil temps down
for those of you that run one (with a stock style pick up) how is yours set up? pics? any info would help
ralph
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: big block oil pump set up for a cooler?where?? [Re: toplescuda] #659154
04/02/10 06:09 PM
04/02/10 06:09 PM
Fredericktown, PA 15333
maundmotorworks Offline
Stealth poster
Stealth poster
Find an oil pump cover off a Chrysler Marine big block engine. Some of those engines had the regular passenger car oil pump and cover, some had a different cover for use with an oil cooler. Another option is to get a pump cover from Milodon for use with remote filters and plumb a cooler into that system.
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
Re: big block oil pump set up for a cooler?where?? [Re: toplescuda] #659155
04/02/10 06:17 PM
04/02/10 06:17 PM
AndyF Offline
AndyF  Offline
Not hard to do at all. Just buy a pump cover that is plumbed for an external filter and then hook up the lines to your cooler. Look at the pump cover on this engine and you'll see what you need.
