Where and how did you mount your fuel pump regulator? #659053
04/02/10 03:27 PM
04/02/10 03:27 PM
Wichita,KS
Blakcharger440 Offline OP
Wichita,KS
I am trying to figure out where and how to mount the holley fuel pump regulator. Even though I will be using my blue pump just for start up and will shut if off immediately, I want to go ahead and mount the regulator.
I know it is supposed to be close to the carb in the engine bay?
Someone please post some pics of how they mounted theirs. Thanks guys!
Re: Where and how did you mount your fuel pump regulator? [Re: Blakcharger440] #659054
04/02/10 03:51 PM
04/02/10 03:51 PM
mount it in front of the carburetor inlets. I'm assuming your running a manual pump so you can plumb it between the mechanicl pump and the carb
Re: Where and how did you mount your fuel pump regulator? [Re: Blakcharger440] #659055
04/02/10 03:55 PM
04/02/10 03:55 PM
Indiana
W5Duster436 Offline
W5Duster436  Offline
Indiana
I purchased the AED stainless line kit. You don't need the AED bracket as the lines will hold it in place.
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
Re: Where and how did you mount your fuel pump regulator? [Re: Blakcharger440] #659056
04/02/10 04:26 PM
04/02/10 04:26 PM
Peoples republic of clackamas ...
atoetly Offline
atoetly  Offline
My regulator is not mounted solid but inbetween my fuel lines next to the carb.
Re: Where and how did you mount your fuel pump regulator? [Re: atoetly] #659057
04/02/10 04:46 PM
04/02/10 04:46 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
X2 on in front of the carb. That way the launch will help feed the card. I don't have a mount, they are just suspended by the lines.
Re: Where and how did you mount your fuel pump regulator? [Re: Bigcube] #659058
04/02/10 05:10 PM
04/02/10 05:10 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Mine is mounted on the right frame rail..down low out of site..right below the alt..
Re: Where and how did you mount your fuel pump regulator? [Re: VernMotor] #659059
04/02/10 05:37 PM
04/02/10 05:37 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
As close to the carb as possible...............
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Where and how did you mount your fuel pump regulator? [Re: chryco] #659060
04/02/10 05:50 PM
04/02/10 05:50 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Where and how did you mount your fuel pump regulator? [Re: Blakcharger440] #659061
04/02/10 07:50 PM
04/02/10 07:50 PM
mo
moparbud Offline
moparbud  Offline
mo
tunnel ram
Re: Where and how did you mount your fuel pump regulator? [Re: moparbud] #659062
04/02/10 08:12 PM
04/02/10 08:12 PM
Sherman Texas
The Shocker Offline
The Shocker  Offline
Sherman Texas
Right ahead of the carb on mine ...
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
