Which rockers fit under stock valve covers? #658888
04/02/10 09:43 AM
04/02/10 09:43 AM
Down under
slantman Offline OP
slantman  Offline OP
Down under
I'm looking to buy a set of rockers to use on my max wedge clone motor. I'll be running a street solid roller, and was thinking of using a set of steel rockers from RAS, however I'd like to see what all my options are. The three main considerations are that they must handle solid roller spring pressures (200 seat, 500 open), live under street driving conditions (though no more than 1000 miles a year) and fit under a set of '63 4 bolt valve covers. Any recommendations?
Re: Which rockers fit under stock valve covers? [Re: slantman] #658889
04/02/10 10:05 AM
04/02/10 10:05 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
just double up on the vc gaskets
Mopar Performance
Re: Which rockers fit under stock valve covers? [Re: slantman] #658890
04/02/10 11:49 AM
04/02/10 11:49 AM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
Harland Sharp do not, which I suppose is useful to know what not to get. DRAM went with stamped steel Moroso valve covers for the 452 in my 70RR and they cleared the Harland Sharps. You could paint them orange and not a lot of people would notice.
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: Which rockers fit under stock valve covers? [Re: David_in_St_Croi] #658891
04/02/10 11:54 AM
04/02/10 11:54 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Wrong
Harland's do fit under the stock covers. So do T&D's, RAS, Crane Golds, and Comp's. Sometimes you need to clearance the baffle(the adjuster screws hit). 5 minutes with a drill bit and you are in business.
Several engines I have built with Harlands with the stock covers and no problems.
Don't double up the gaskets. They will likely leak if you do....
MB
Re: Which rockers fit under stock valve covers? [Re: slantman] #658892
04/02/10 11:59 AM
04/02/10 11:59 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Harland Sharps on this Maxie.
Re: Which rockers fit under stock valve covers? [Re: HPMike] #658893
04/02/10 12:18 PM
04/02/10 12:18 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
cool pic....... On doubling up gaskets I ran a sealer in between the 2 and nothing leaked. just sayin
Mopar Performance
Re: Which rockers fit under stock valve covers? [Re: HPMike] #658894
04/02/10 12:51 PM
04/02/10 12:51 PM
Wrong
MB
Just reporting the experience DRAM had. We had already clearanced the baffles for the stock iron rockers that were on there originally. The heads are Edelbrocks so maybe a difference there, even though they use stock valve trains.
Re: Which rockers fit under stock valve covers? [Re: David_in_St_Croi] #658895
04/02/10 12:57 PM
04/02/10 12:57 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
Harland Sharps under here too.
Re: Which rockers fit under stock valve covers? [Re: HPMike] #658896
04/02/10 08:41 PM
04/02/10 08:41 PM
Down under
slantman Offline OP
slantman  Offline OP
Down under
Does it matter what ratio is used, as far as valve cover clearance is concerned?
Re: Which rockers fit under stock valve covers? [Re: slantman] #658897
04/02/10 08:53 PM
04/02/10 08:53 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
While I haven't tried all combinations, I haven't run into any problems yet.
MB
