Headers for 68 GTX 440 #658800
04/02/10 06:06 AM
04/02/10 06:06 AM
Ia
4spdana Offline OP
4spdana  Offline OP
Ia
what are headers worth over magnum manifolds ?
+.030 440, 9.5 comp, 906 2.14 / 1.88 with Bowl Work, Extreme Energy 268, Performer Dual Plane, 68 Production Carter AVS
Re: Headers for 68 GTX 440 [Re: 4spdana] #658801
04/02/10 09:46 AM
04/02/10 09:46 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Depends on the rest of the exhaust. If you'r running a stock 2 1/4" exhaust maybe 10-15hp but when you go up in size and add decent mufflers maybe 25.
Coming soon!!!!
Re: Headers for 68 GTX 440 [Re: 4spdana] #658802
04/02/10 10:00 AM
04/02/10 10:00 AM
what are headers worth over magnum manifolds?
I cannot ans that Q directly but keep in mind that any dia reduction past the header collector flange which includes the collector reducer hurts flow and therefore your power. any backpressure past that point is detrimental (though you will always have some). I'd bite the bullet and do it right starting w some ($)tti's($) and a 3" mandrel bent system from front to rear w dynomax super turbos (walker 17769 I believe) and an X pipe in the middle and resonators(both of these are critical for noise reduction) of some sort rearward in the pipes along the springs. Have you rejetted the oe AVS. If not an eddy strip kit (there's 6 of em) but get the one w the rods/jets close to what you have now along w a pair of AFB flat metering rod caps would benefit you. The 2 step eddy rods require a 2 step type eddy jet as opposed to the oe AVS 3 step rods/3 step type jets. All oe AVS's are emission calibrated and you WILL notice a difference w rejetting and w headers you'll need to rejet anyway.
Re: Headers for 68 GTX 440 [Re: 4spdana] #658803
04/02/10 10:16 AM
04/02/10 10:16 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Headers and a good free flowing exhaust with X pipe or minimum H pipe will pump it up a lot.
On your combo the exhaust valves are a little too big and the cam is a tad small for the heads and an RPM performer is a better choice but yea got what yes got.
what is the gears tranny and torque convereter.
A 3310 750 vac would be a good crab unless it's 4 speed then a 750 DP.
Re: Headers for 68 GTX 440 [Re: 4spdana] #658804
04/02/10 10:41 AM
04/02/10 10:41 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
In a true apples to apples comparison, maybe 20 hp. If you plan to continually add power going forward, the benefit of the headers will become even greater.
Re: Headers for 68 GTX 440 [Re: BSB67] #658805
04/02/10 01:40 PM
04/02/10 01:40 PM
Ia
4spdana Offline OP
4spdana  Offline OP
Ia
sorry, the valve sizes were 2.14 / 1.81
the pipes on back would be 2-1/2 , unless 3" would be considered a gain, but maybe not with manifold exit i.d. or collector size
would do at least a H-pipe
1800 stall, 3.23 on the drive train
thanks for the help
Re: Headers for 68 GTX 440 [Re: 4spdana] #658806
04/02/10 03:06 PM
04/02/10 03:06 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
with a full stock style exhaust you'd be lucky to see a 5 or 8 HP gain with headers on a dyno.
Re: Headers for 68 GTX 440 [Re: 4spdana] #658807
04/02/10 08:06 PM
04/02/10 08:06 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
thanks for the help
that stall and gear are gonna kill ya.
Re: Headers for 68 GTX 440 [Re: Mr.Yuck] #658808
04/02/10 08:19 PM
04/02/10 08:19 PM
Dougsmopars Offline
Dougsmopars  Offline
A little more converter would make a big difference
Re: Headers for 68 GTX 440 [Re: Mr.Yuck] #658809
04/02/10 08:26 PM
04/02/10 08:26 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
thanks for the help
Ya, real performance killers
Re: Headers for 68 GTX 440 [Re: BSB67] #658810
04/02/10 08:41 PM
04/02/10 08:41 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
thanks for the help
yes they are he doesn't have a $$$ 500ci speciality built wedge like you.
Re: Headers for 68 GTX 440 [Re: Mr.Yuck] #658811
04/02/10 08:51 PM
04/02/10 08:51 PM
I just installed a six pack Eddy head in a 69 GTX today--TTI 1 3/4 inch fit like a DREAM! Power steering and all--The bigger tubes are really for the big HP--I love the 1 3/4 for STREET stuff
Re: Headers for 68 GTX 440 [Re: Mr.Yuck] #658812
04/02/10 10:22 PM
04/02/10 10:22 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
thanks for the help
Went 12s with a 440 and a .455 lift cam and compression bent exhaust.
Plus, you can put more into the motor when you don't have to buy a gear, a torque converter, and tires.
Re: Headers for 68 GTX 440 [Re: BSB67] #658813
04/03/10 08:21 AM
04/03/10 08:21 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I'd go with 3" exhaust right off (not much more money) works best and if you start to grow more hp you are already set
