W2 Rocker Arms
#658698
04/01/10 11:37 PM
04/01/10 11:37 PM
Posts: 70 West Coast
Dr340w2
All Talk. No Action.
West Coast
Just wondering about different rocker arms that are being used on w2 motors?
aka: Albergetti
Re: W2 Rocker Arms
[Re: Dr340w2]
#658700
04/02/10 12:09 AM
04/02/10 12:09 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Welcome to the jungle I have 2 systems... one is the blue MP (which is a Crane rocker) and 2nd is TD... the TD is a better system if you are into a bigger cam... I should also state that both of these are roller cam engines in the .650 or better lift
Re: W2 Rocker Arms
[Re: The Shocker]
#658702
04/02/10 06:30 AM
04/02/10 06:30 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
IMO if this is a new build your only choices are Harland Sharp, Jesel or T&D. Since Crane and Erson are no longer around it limits the options. Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
Re: W2 Rocker Arms
[Re: sleepyhead416]
#658704
04/02/10 07:35 AM
04/02/10 07:35 AM
Posts: 5,066 new jersey usa
11secdart
new jersey usa
590 lift M/P mechanical cam, original W2 ductile iron rockers. I`ve never broken one since I started using them over 15 years ago. But then again we have a little " trick" we use which I`m sure helps. A very thin roller bearing between each rocker on the shaft.
Re: W2 Rocker Arms
[Re: 11secdart]
#658705
04/02/10 09:08 AM
04/02/10 09:08 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
Crane Gold 1.6 Roller Rockers.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: W2 Rocker Arms
[Re: ScottSmith_Harms]
#658710
04/02/10 03:08 PM
04/02/10 03:08 PM
Dr340w2
West Coast
Thank You for all the helpful info. This is a high compression roller cam 340. No Stroker. W2's (oval port) single carb.
aka: Albergetti
Re: W2 Rocker Arms
[Re: Dr340w2]
#658711
04/02/10 05:02 PM
04/02/10 05:02 PM
Plumb Wired
Blue Ridge, VA
My point was that there are only a few manufacturers still in business. Crane, MP (Crane), Erson and Norris all made good pieces but are no longer around so if you buy a set of them used and break one your good luck finding replacements. Just ask me how I know! Mike Gray
RIP Monte Smith
Re: W2 Rocker Arms
[Re: Plumb Wired]
#658713
04/02/10 05:35 PM
04/02/10 05:35 PM
Dr340w2
West Coast
Thank You very much for the info. P.S. Fast small blocks do rule!
aka: Albergetti
Re: W2 Rocker Arms
[Re: Plymouth340]
#658715
04/02/10 07:41 PM
04/02/10 07:41 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Norris is still making then...i just talked to then 3 days ago and he is sending me my w2 replacement rockers..
I know they had some loose rockers. (not enough to make up a full set) but, unless something has changed from a few weeks ago, they aren't making anymore.
It would be nice though.
Re: W2 Rocker Arms
[Re: Dr340w2]
#658716
09/07/12 10:07 PM
09/07/12 10:07 PM
Posts: 82 Cape Coral
65 DODGE POST
Cape Coral
Hello guys...this is an old thread...just joined and can't figure how to post? Anyways I am getting these heads in two weeks... http://www.ebay.com/itm/300774739401?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649They are late 1977 810 castings....race versions...I read somewhere on the early W2's you have to use an assembly like the Harlands...I do not have the heads in front of me but I am getting them shipped here soon. who knows the offset? .775 or .500? I'm just trying to get a head start so I can computer shop until they arrive.. Thanks Jim
65 DODGE CORONET 440 INDY EZ HEADS STRANGE S60
Re: W2 Rocker Arms
[Re: 65 DODGE POST]
#658717
09/07/12 10:46 PM
09/07/12 10:46 PM
MR_P_BODY
You do know thats a single head
