Re: Convert a single field alternator to a dual?
[Re: Blue69Charger]
#658420
04/01/10 08:25 PM
04/01/10 08:25 PM
RapidRobert
I have not done it but I understand that you can take an insulated brush assy from either of the field terminals from any dual field alt & sub it in instead of the grounded brush assy on the earlier one in question.
[Re: Blue69Charger]
#658424
04/02/10 12:08 AM
04/02/10 12:08 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
just need to drill couples of holes on housing blank space and install a brush and isolator there, removing the old grounded brush:
[Re: NachoRT74]
#658427
04/02/10 11:25 PM
04/02/10 11:25 PM
Posts: 584 San Jose, CA
Blue69Charger
San Jose, CA
Thanks NachoRT74. My alternator is spaced out from the block farther than stock because I am using the BPE hidden a/c compressor brackets. Block clearance was fine, but the alternator ear was hitting the upper alternator bracket. I read your other post. Does Beck Arnley list a different part number for the hidden stator and the visible stator squarebacks? The brand I have uses the same part number for both types of alternators. 90% of the ones I've found are the hidden stator type which makes getting a warranty replacement hard. Has anyone tried the powermaster retro alternators? http://www.powermastermotorsports.com/mopar.html They look nice and have a butterscotch stator. Are they good quality and rebuilt in the US?
[Re: Blue69Charger]
#658428
04/03/10 12:52 AM
04/03/10 12:52 AM
NachoRT74
Valencia, España
this is the funny part on this... laters squarebacks were more on production. Earliers were just around 5-6 years. Then rest of 70s and all 80s used the later.
Beck/Arnley list diff PN for everyone... 4 PNs for them... 2 earliers and 2 laters, with 1 and with 2 grooves pulleys each one.
2 grooves pulley on lates is the 78 amps one.
AC Delco and Remy too, just that they don't list the lates 2 grooves alts.
some are also 65 amps
[Re: Blue69Charger]
#658430
04/03/10 04:18 PM
04/03/10 04:18 PM
NachoRT74
Valencia, España
there is also ORIGINAL roundbacks alts with dual prongs.
My knowledgement about is they began to be installed on lates 69s C bodies, being standart in all 70s
In fact those 69s have both provisions for dual prong or single prong ( grounded brush )
[Re: NachoRT74]
#658431
04/03/10 04:20 PM
04/03/10 04:20 PM
NachoRT74
Valencia, España
I did know I was already talked about the regular single field ( prong ) roundback to a dual with an easy job. This is a pic I already prepared long time ago:
( well on number three is really an original dual prong already factory made, like the one I did show above, but to get the idea of the final look )
[Re: NachoRT74]
#658432
04/03/10 04:28 PM
04/03/10 04:28 PM
NachoRT74
Valencia, España
then on lates 70s I think and all 71s where on this way.
( I can be some wrong on exactly dates when they appeared, but more less must be on that way )
Note, not anymore the grounded brush provision
[Re: NachoRT74]
#658433
04/03/10 04:33 PM
04/03/10 04:33 PM
NachoRT74
Valencia, España
I think this makes a total of 5 alternators changes allong lates 60s and all 80s, without ouput and pulley considerations, just about exterior looks and setup. Being more critical changes the 69-72 period
1-Roundback single prong 2-Roundback with both setup provisions ( single and double 3-Roundbacks double prong 4-Squarebacks with visible stator 5-Squarebacks with hidden stator ( wider housing and stator windings, also one diff brush isolator )
