Leaking Rear Main Seal #658351
04/01/10 05:20 PM
04/01/10 05:20 PM
Nanaimo, B.C.
GwaiiEagle Offline OP
Mannix
Mannix
Nanaimo, B.C.
Big time leak, I think I may have put both halves with the edge nearest the back of the motor not the front.
Can you loosen the main caps enough to get the seal below the crank out?
Re: Leaking Rear Main Seal [Re: GwaiiEagle] #658352
04/01/10 09:15 PM
04/01/10 09:15 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Yes you can. Use a wooden dowel to help push the seal around the crank so you don't scar it. Then you can grab the seal with some pliers to remove it the rest of the way. Just rotate it out of there.
And yes you'll need a new seal
Oh and oil the new one up good to help with install.
