Page 3 of 4 1 2 3 4
Re: anyone have GOOD luck with the mopar alum hemi head [Re: hemi_doug] #658125
04/04/10 08:02 PM
04/04/10 08:02 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Here is a hint that the "trouble" is on it's way....
IF you have a valve tap that comes and goes...SHUT IT DOWN AND GET THOSE FREEKIN HEADS OFF THAT MOTOR ASAP!
OK, there is something to this. Last year toward the end of the year, I kept getting, what I thought was a loose lifter. The noise would come and go, but eventually it would only get loud when the engine warmed up. It was coming from the right bank (#6 failed). When I pulled it apart, #3 cam bearing had turned. I thought that was the source of the ticking.
Jeez, maybe it was the seat telling me a along it was ready to fall out. I had a suspicion that that was the cause, but I figured there was no in between (either its in or its out).
Could I have been wrong?
Re: anyone have GOOD luck with the mopar alum hemi head [Re: torkrules] #658126
04/05/10 08:17 AM
04/05/10 08:17 AM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
YES!
71 440-6 4spd & 69 Hemi 4spd
Post deleted by Defbob [Re: torkrules] #658127
04/05/10 08:56 AM
04/05/10 08:56 AM
Re: anyone have GOOD luck with the mopar alum hemi head #658128
04/05/10 09:03 AM
04/05/10 09:03 AM
malvern, ohio
3
3ddart Offline OP
3ddart  Offline OP
malvern, ohio
any other takes on this snafu!
Re: anyone have GOOD luck with the mopar alum hemi head #658129
04/05/10 09:03 AM
04/05/10 09:03 AM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
We are talking pre Edelbrock heads, aren't we? Do any of the newer aluminum heads have this problem?
Re: anyone have GOOD luck with the mopar alum hemi head [Re: maximus] #658130
04/06/10 10:20 PM
04/06/10 10:20 PM
malvern, ohio
3
3ddart Offline OP
3ddart  Offline OP
malvern, ohio
anybody have a time frame (dates of manufacture) on the suspect heads? dave
Re: anyone have GOOD luck with the mopar alum hemi head [Re: maximus] #658131
04/08/10 07:09 AM
04/08/10 07:09 AM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
My understanding is that the Edelbrocks, Stage V, Indy, have not hand any problems so far.
Re: anyone have GOOD luck with the mopar alum hemi head [Re: 3ddart] #658132
04/08/10 07:12 AM
04/08/10 07:12 AM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Dave,
I bought mine late 2006/early 2007 (my memory's not what it used to be). So lets say thay sat on the shelf for a while. A safe bet would be 2004 until the Edelbrocks came out.
Re: anyone have GOOD luck with the mopar alum hemi head [Re: torkrules] #658133
04/08/10 09:04 AM
04/08/10 09:04 AM
malvern, ohio
3
3ddart Offline OP
3ddart  Offline OP
malvern, ohio
john: i bought mine in dec, 2005. that puts me right in the mix. they came from a local dodge dealer so i don't think they would have had them very long. also the guy that did the valve job said he saw no indication that anything was amiss, BUT!!! i'm still not sure what i'm going to do yet. dave
Re: anyone have GOOD luck with the mopar alum hemi head [Re: 3ddart] #658134
04/13/10 02:29 AM
04/13/10 02:29 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
Here is a old picture of mine.
Re: anyone have GOOD luck with the mopar alum hemi head [Re: SCATPK] #658135
04/13/10 02:30 AM
04/13/10 02:30 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
Head.
Re: anyone have GOOD luck with the mopar alum hemi head [Re: 3ddart] #658136
04/13/10 07:04 AM
04/13/10 07:04 AM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
FWIW, I had the heads apart over the past winter to upgrade the springs for a mild roller cam and to clean up all of the baked on oil from the intake mismatch. I had to scrape crud off all the intake valves. I lapped the valves myself and didn't see anything out of the ordinary.
The engine ran fine all last year, but I was experiencing an intermittent tick that I thought were the hydraulic lifters. Toward the end of the year, the tick got more predictable (fine when cold but as soon as the engine warmed up it was there). At the end of the year I had it on the dyno to try to figure out what was going on. We pinned it to the right bank near the rear (#6 had the seat problem).
I thought the valve seat might be the culprit but I figured it would have just fallen right out. When I took the engine apart, I found #3 cam bearing oil hole had either turned 340 degrees or it was put in wrong. I always check everything so I doubt I would miss something that fundamental so I assumed thats what the ticking was. Now I think it was the seat trying to tell me something
Re: anyone have GOOD luck with the mopar alum hemi head [Re: SCATPK] #658137
04/13/10 07:05 AM
04/13/10 07:05 AM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I hate seeing stuff like that
Re: anyone have GOOD luck with the mopar alum hemi head [Re: SCATPK] #658138
04/13/10 12:54 PM
04/13/10 12:54 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
What year were those heads?
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: anyone have GOOD luck with the mopar alum hemi head [Re: Hemi Allstate] #658139
04/13/10 01:13 PM
04/13/10 01:13 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Keep me in your prays....Pic of the new MP castings
Can a potential problem bee seen visually when performing a valve job on a problematic valve seat, I wonder
Re: anyone have GOOD luck with the mopar alum hemi head [Re: Bob_Coomer] #658140
04/13/10 01:21 PM
04/13/10 01:21 PM
Mt. Eden Ky.
Mt. Eden Ky.
Bob, I haven't heard anything negative about the Edelbrock Heads.
Isn't that what yours are?
Mark
1996 Ram 1500 Sport
1968 road runner
Re: anyone have GOOD luck with the mopar alum hemi head [Re: Bob_Coomer] #658141
04/13/10 04:17 PM
04/13/10 04:17 PM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Could not tell with mine and I had the valves out. If you have the edelbrocks, you are good to go.
Re: anyone have GOOD luck with the mopar alum hemi head [Re: torkrules] #658142
04/15/10 02:01 PM
04/15/10 02:01 PM
malvern, ohio
3
3ddart Offline OP
3ddart  Offline OP
malvern, ohio
man this blows me away that only a couple of guys have spoke up positivly about this! not a good indication of faith! does any of the mp guys on here have anyhting to report? dave
Re: anyone have GOOD luck with the mopar alum hemi head [Re: 3ddart] #658143
04/15/10 03:06 PM
04/15/10 03:06 PM
Kansas, USA
V
Venomvpr900 Offline
Venomvpr900  Offline
V
Kansas, USA
Probably not because their customer service is like the quality of their parts ... non-existant
1987 D-100 SWB, 390hp/360ci Mopar Performance Crate, Built 998 trans, 9.25 axle with sure-grip and 3.92's - 3960#'s with driver 13.83 @ 96.36 1.98 60 ft 2003 Dodge Ram 2500 HD 5.7ltr HEMI!!!
Re: anyone have GOOD luck with the mopar alum hemi head [Re: Venomvpr900] #658144
04/16/10 09:11 AM
04/16/10 09:11 AM
malvern, ohio
3
3ddart Offline OP
3ddart  Offline OP
malvern, ohio
maybe, but david h and skippy (and maybe others) get on here, so if they know something it would be nice to hear from them!!!! dave
Page 3 of 4 1 2 3 4
