Re: Shaker 440 4bbl feet placement help
[Re: floyd]
#657763
04/01/10 07:37 PM
04/01/10 07:37 PM
Posts: 322 MERRILLVILLE, INDIANA
sunroof446
I'm not certain 440-4bbl shakers had feet. If they did, I'd guess the tabs would have been positioned the same as on a 440-6. I can get some measurements off a sixpack base if you want them. Moparts member mccanix probably can clear that up. I feel like he had the engineering drawings and it showed no feet for the 4bbl. There's also a post here about the MATS show. There was an original 440-4bbl shaker car there. I know the owner and can send him an email to see what he had (assuming he had the original base). I think a 440-4bbl shaker is probably the rarest of the shakers.
Got the measurements. Thanks, JOE
[Re: sunroof446]
#657764
04/01/10 09:48 PM
04/01/10 09:48 PM
Posts: 4,784 Ontario, Canada
mccannix
Ontario, Canada
Correct...no feet provisions for a 440 shaker base. They were super low production. The 440 shaker base does not have the hole in the front boss like most 383 shaker bases that housed the rod style foot. The owner of the 440 shaker car at the MATS show has the correct base with no feet
