tourqueflite questions??? #65716
05/29/08 03:22 PM
05/29/08 03:22 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
What is the easiest way to raise the lockup point in a 79 904?
Also is there a way to just disable it with out disasembleing the trans?
Re: tourqueflite questions??? [Re: HotRodDave] #65717
05/29/08 04:35 PM
05/29/08 04:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The only way that I know of is to increase the pressure of the lockup valve spring which requires valve body removal.
Re: tourqueflite questions??? [Re: John_Kunkel] #65718
05/29/08 05:18 PM
05/29/08 05:18 PM
Kalispell Mt.
Kalispell Mt.
Thanks John! I was hopeing you would see this.
Removeing the VB is easy, where do I find the spring and do I just shim it or make a blocker rod or what. Is it the valve in the VB where the tube goes in, the extra valve on top of the VB?
Re: tourqueflite questions??? [Re: HotRodDave] #65719
05/29/08 06:20 PM
05/29/08 06:20 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Be a heck of alot easier and reliable to install an old none lock up transmission.
You nalso have to mess with the lock up converter.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: tourqueflite questions??? [Re: HotRodDave] #65720
05/29/08 06:58 PM
05/29/08 06:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's the location of the lockup valve/spring. There is an aftermarket source for springs, can't remember who; the valve can be blocked to eliminate the lockup function.
Re: tourqueflite questions??? [Re: John_Kunkel] #65721
05/30/08 12:09 PM
05/30/08 12:09 PM
Kalispell Mt.
Kalispell Mt.
Thanks John
Exactly what I suspected.
