tourqueflite questions???
#65716
05/29/08 03:22 PM
05/29/08 03:22 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
What is the easiest way to raise the lockup point in a 79 904?
Also is there a way to just disable it with out disasembleing the trans?
Re: tourqueflite questions???
[Re: HotRodDave]
#65717
05/29/08 04:35 PM
05/29/08 04:35 PM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The only way that I know of is to increase the pressure of the lockup valve spring which requires valve body removal.
[Re: John_Kunkel]
#65718
05/29/08 05:18 PM
05/29/08 05:18 PM
HotRodDave
Kalispell Mt.
Thanks John! I was hopeing you would see this.
Removeing the VB is easy, where do I find the spring and do I just shim it or make a blocker rod or what. Is it the valve in the VB where the tube goes in, the extra valve on top of the VB?
[Re: HotRodDave]
#65719
05/29/08 06:20 PM
05/29/08 06:20 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Be a heck of alot easier and reliable to install an old none lock up transmission. You nalso have to mess with the lock up converter.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: John_Kunkel]
#65721
05/30/08 12:09 PM
05/30/08 12:09 PM
HotRodDave
Kalispell Mt.
Thanks John Exactly what I suspected.
