Re: Dizzy Lock it out or not?
[Re: TheOtherDodge]
#657095
03/31/10 05:32 PM
03/31/10 05:32 PM
Posts: 6,295 U.S.
moparniac
U.S.
I ran the light blue and silvers before with black bushing on my old setup but some swear by the lock out and some say kickback issues can bite ya being locked out!
Mopar Performance
[Re: moparniac]
#657096
03/31/10 05:34 PM
03/31/10 05:34 PM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
mine i locked out but i use a start/retard box
WAXER
[Re: moparniac]
#657099
03/31/10 05:55 PM
03/31/10 05:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Why would it say on kick backs... that can occur when the timing is up... not down... I use advance in mine ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#657100
03/31/10 06:10 PM
03/31/10 06:10 PM
Posts: 6,295 U.S.
moparniac
U.S.
this is whats confusing? says no locked out timing in summits webaite then look below ... http://www.summitracing.com/parts/MSD-8970/These MSD Three Stage retard controls allow you to retard your ignition timing in three different stages. You can activate one retard for a nitrous stage, and another at top-end in high gear for more mph, and still have another module left over for dual-stage nitrous systems. When activated together, the retard amounts are cumulative, so you get the total of the three. For example, if you pull 2 degrees, then 4 degrees on the second stage, and another 2 degrees at top-end, the total retard is 8 degrees (2+4+2=8). In addition to the individual retard stages, the Three Stage retard controls have an optional start retard function that retards the timing 10 or 25 degrees while cranking the engine. This makes starting high-compression engines with locked-out timing, such as crank trigger systems, much easier. These units easily connect to your MSD Ignition and can be triggered from points, electronic ignitions, crank triggers, or magnetic pickup distributors. They're supplied with a 2, 3, and 4 degree module, and must be used with an MSD 6, SCI, 7, 8, or 10 Series ignition.
Mopar Performance
[Re: moparniac]
#657105
03/31/10 07:40 PM
03/31/10 07:40 PM
Posts: 4,210 New York
polyspheric
New York
Good reason to lock it out on a street car: can't move, one less thing to worry about. Most common reason to lock it out on a street car: "all the kewl kids do it". Reason why kewl kids lock it out on a street car: they don't understand what it does (much the same as why they remove the choke, power valve, thermostat, and vacuum advance).
Boffin Emeritus
[Re: emarine01]
#657107
03/31/10 07:56 PM
03/31/10 07:56 PM
Posts: 6,295 U.S.
moparniac
U.S.
i like the retard option/locked out I guess ![](/ubbthreads/images/graemlins/biggrin.gif) the stage 3 directions/summit are vague! ![](/ubbthreads/images/graemlins/thumbs.gif) see pic above ![](/ubbthreads/images/graemlins/biggrin.gif)
Mopar Performance
[Re: moparniac]
#657108
03/31/10 08:11 PM
03/31/10 08:11 PM
Posts: 1,200 UK
602heavy
UK
The 3 retard wires must be grounded for zero retard or just fit a zero pill in the box , i have the retard wires hooked up to the 12 volt side of solinoids , when the noids arn't activated the retard wire/s will be earthed , a soon as the noids are fired off the box will pull retard depending on what pill is in the box , the start retard hooks up to the starter solinoid . this can be 10*/25* depending if link wire is cut , timing has to be advanced 4* when this box is initially hooked up , ran this for a while now with no issues , i use a dial retard instead of the pills , also use two stages out of the three. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: moparniac]
#657110
03/31/10 08:18 PM
03/31/10 08:18 PM
Posts: 3,695 nc
emarine01
nc
i like the retard option/locked out I guess the stage 3 directions/summit are vague! see pic above
Hey most people choose not to be retarded Sorry Wedgie but I could not stop myself ![](/ubbthreads/images/graemlins/devil.gif)
[Re: 602heavy]
#657111
03/31/10 08:22 PM
03/31/10 08:22 PM
Posts: 6,295 U.S.
moparniac
U.S.
how are you pulling out timing in high gear if needed?
Mopar Performance
