Are all big block intermediate shafts the same length? #657039
03/31/10 02:09 PM
03/31/10 02:09 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Are all big block intermediate oil pump shafts the same length? I need a new bronze unit for a roller cam and I know when we first got this motor ready to fire last winter I had one that was too long but can't remember why??
I have a 400 low deck block, Melling oil pump with an Indy cover on it. Single line external oiling.
Re: Are all big block intermediate shafts the same length? [Re: ProSport] #657040
03/31/10 02:14 PM
03/31/10 02:14 PM
organ
maximum entropy Offline
organ
nope. there are three that i know of- maybe four, depending on if it's low deck, rb, milodon pump, etc.
Re: Are all big block intermediate shafts the same length? [Re: ProSport] #657041
03/31/10 02:15 PM
03/31/10 02:15 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
the longer unit is for the race unit that feeds the pump from both ends. it has like an extra plate sandwiched between the pump & the block.
Re: Are all big block intermediate shafts the same length? [Re: rebel] #657042
03/31/10 03:10 PM
03/31/10 03:10 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
The stockers are the same length. There is some different lengths for the hex part due to the depth of some of the racing pumps, but if you are using a stock type pump use any of the big block shafts...unless you have a roller cam.
In your case, you will need the bronze gear for the roller, and you will need the extended hex drive for the deeper pump.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: Are all big block intermediate shafts the same length? [Re: Steve1118] #657043
03/31/10 04:06 PM
03/31/10 04:06 PM
organ
organ
yup. my bad. old age?
Re: Are all big block intermediate shafts the same length? [Re: maximum entropy] #657044
03/31/10 04:14 PM
03/31/10 04:14 PM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
there is also an extra long one for the Keith Black double pumps.
Re: Are all big block intermediate shafts the same length? [Re: SG duster] #657045
03/31/10 09:24 PM
03/31/10 09:24 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
The Barton billet alum. pump is longer also.
Re: Are all big block intermediate shafts the same length? [Re: SG duster] #657046
03/31/10 09:27 PM
03/31/10 09:27 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Thanks guys, I just took mine out tonite to measure it, should have just done that in the first place. Funny thing is I didn't even measure it as I expected it to be worn badly and in need of replacement but it is fine.
Re: Are all big block intermediate shafts the same length? [Re: ProSport] #657047
03/31/10 09:31 PM
03/31/10 09:31 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
if you're not using anything between the melling pump and block you need a stock length shaft which is the shortest one. iirc of the three "common" lengths the stock pump uses the shortest, the milodon external feed pump uses the next longest and using a stock type pump with the milodon external feed spacer uses the longest one.
Re: Are all big block intermediate shafts the same length? [Re: ProSport] #657048
04/01/10 01:05 AM
04/01/10 01:05 AM
AndyF Offline
AndyF  Offline
Three different lengths, all available in either bronze or steel. Total of 6 different part numbers. This info is in my book.
