70 E body 3 speed reverse light? #65645
05/29/08 11:19 AM
05/29/08 11:19 AM
Tampa, FL
70RTvert Offline OP
70RTvert  Offline OP
Tampa, FL
Hi Guys,
Do 70 E bodies with 3 speed tranny,s get the reverse light on the dash? Also do all 4 speeds get the light or is it an option? I've got a rough 70 Challenger 340 shell that had a standard trans with the original dash in the car but it doesn't have the hole for the reverse light. No fender tag so I'm wondering if maybe it was a 3 speed?
Thanks for your help.
Doug
Re: 70 E body 3 speed reverse light? [Re: 70RTvert] #65646
05/29/08 11:29 AM
05/29/08 11:29 AM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
Three speed cars have no reverse light ever. I have 1 70 car and two 71 cars that are three speeds. ALL four speed cars have the reverse light, it is not an option, but is standard or required on all four speed cars. Hope this helps you out.
Re: 70 E body 3 speed reverse light? [Re: m46rat] #65647
05/29/08 11:46 AM
05/29/08 11:46 AM
Tampa, FL
70RTvert Offline OP
70RTvert  Offline OP
Tampa, FL
Yes, that helps. Thanks a lot for your input.
Doug
Re: 70 E body 3 speed reverse light? [Re: m46rat] #65648
05/29/08 02:01 PM
05/29/08 02:01 PM
Pa
K
koak Offline
koak  Offline
K
Pa
I can verify what M47 said. I added the reverse light to mine so it looked more like a 4-speed way way back (think Carter administration...)
