nylon tubing in fuel system. how to connect it. #65624
05/29/08 09:54 AM
05/29/08 09:54 AM
Andrewh Offline OP
Andrewh  Offline OP
Dorman makes nylon tubing that is supposed to be stock in new mustangs.
Since I am switching my coronet to efi, and needed a new fuel line and return, this seemed like a good way to go.
I bought the 5/16th size tubing.
But I realized, I have no idea how to hook this into the regular fuel line setup. It has no give like rubber, plus I don't really want to hose clamp the stuff.
I have to get it to 3/8's barb fitting, 5/16 barb fitting on this pump.
http://store.summitracing.com/partdetail...mp;autoview=sku
Then run it up front to a this filter
then to this fuel regulator with an -10 fittings, which feets found the adapter to get it down to a 3/8's npt fitting for the fuel filter and the outlet
Plus from the an-6 return on the regulator to the 5/16 or whatever size pipe we put into the sending unit.
Any ideas?
Re: nylon tubing in fuel system. how to connect it. [Re: Andrewh] #65625
05/29/08 09:55 AM
05/29/08 09:55 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Nylon tubing?...gasoline??
Re: nylon tubing in fuel system. how to connect it. [Re: Challenger 1] #65626
05/29/08 10:12 AM
05/29/08 10:12 AM
Andrewh Offline OP
Andrewh  Offline OP
yep.
800061, Dorman [Fuel Injection Repair Kit] 5/16 Nylon Tube
"Connector: 3/8'' Nylon Tubing; Fuel Line Connector"
Part Number: 800075
Manufacturer: DORMAN HPX
Our Price: $11.94
Discount: 5%
Net Price : $11.33
Re: nylon tubing in fuel system. how to connect it. [Re: Challenger 1] #65627
05/29/08 11:26 AM
05/29/08 11:26 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
It's a form of Nylon and quite common in late model vehicles with high pressure EFI systems.
I just don't know if I can use Home Depot type compression fittings or if it requires something special.
- Stu Harmon
Re: nylon tubing in fuel system. how to connect it. [Re: feets] #65628
05/29/08 12:49 PM
05/29/08 12:49 PM
Las Vegas
JeffC Offline
JeffC  Offline
Las Vegas
Re: nylon tubing in fuel system. how to connect it. [Re: JeffC] #65629
05/29/08 12:52 PM
05/29/08 12:52 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Something like this should work. http://www.fmsiinc.com/nylon-steel-compression-union.htm
veddy interesting...
I'll have to look for a non-kanookian source.
- Stu Harmon
Re: nylon tubing in fuel system. how to connect it. [Re: JeffC] #65630
05/29/08 05:46 PM
05/29/08 05:46 PM
Andrewh Offline OP
Andrewh  Offline OP
Thanks. Found a US supplier and ordered a few. I think that was the last piece I needed to figure it out.
Re: nylon tubing in fuel system. how to connect it. [Re: feets] #65631
05/29/08 06:06 PM
05/29/08 06:06 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Actually Dorman makes a kit to press the line on the fittings.They are pricey about 150 bucks.Id be worried about the compression fitting cuttin into the plastic.Ive repaired probally hundreds of those plastic lines at work.The old way was to buy the OE type connector and the line and heat the line with boiling water and work it on.That waqs the fix till the kits came out.Rocky
Chrysler Firepower
Re: nylon tubing in fuel system. how to connect it. [Re: therocks] #65632
05/29/08 06:38 PM
05/29/08 06:38 PM
Andrewh Offline OP
Andrewh  Offline OP
saw that kit. It lists for 299 or something like that, but I don't need a repair kit, since it comes with way too much stuff.
It looks like all the parts are going to run me around 80 bucks anyway.
Might have been better off buying braided hose, but oh well.
