1/4 mile ET/HP calc
#655974
03/30/10 03:19 PM
03/30/10 03:19 PM
Posts: 10 us
0x01b8
us
I'm the guy that wrote the 'RPM/Speed Visual calc' that's linked up in the Tech Archive section. I just finished working on a new calculator and thought you might get some use out of it - 1/4 Mile ET, HP, and MPH Visual Calculatorthanks for reading -john
Re: 1/4 mile ET/HP calc
[Re: RapidRobert]
#655977
03/30/10 03:40 PM
03/30/10 03:40 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
its nice but i dont agree with it. for example, i dont think it takes 640 rwhp at 3650 lbs to run a slow 10.43 maybe i'm using it wrong
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#655978
03/30/10 08:11 PM
03/30/10 08:11 PM
Posts: 4,313 Prospect, PA
BSB67
Prospect, PA
I like the old "Drag Strip Dyno" by Mopar or the Moroso Power Speed calculator. I mostly use the Moroso calculator any more as that is what most everyone else uses, and that makes it apples to apples when comparing numbers between cars. The Drag Strip Dyno has really good info in the text for understanding, but it seems to generate power numbers that are a little higher.
[Re: sixpackgut]
#655979
03/30/10 09:31 PM
03/30/10 09:31 PM
Posts: 10 us
0x01b8
us
The formula I'm using is the same one that's all over the net in other calcs which is the Patrick Hale formula. If you punch in that hp/weight into the calc in the mopart's tech archive you'll get almost the same et. So I don't know what to say about it.
Are you saying the 10.43 was slow or the mph that my program was showing was slower than you expected, or both? The whole deal is kinda ballpark but I'd like it to be as accurate as I can make it.
thanks for the comments
[Re: 0x01b8]
#655984
03/31/10 04:58 PM
03/31/10 04:58 PM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
i just tried it on 2 cars that i know the weight and hp numbers from the dyno.if you adjust the hp scale so the hp numbers from the dyno match the hp numbers at the fywheel it is pretty dead on with the actual et/mph for the 2 cars
WAXER
[Re: QWK_ENUF]
#655985
03/31/10 05:46 PM
03/31/10 05:46 PM
Posts: 10 us
0x01b8
us
Hey - can you tell me the hp/et/mph for your two cars? That would really help me get this thing dialed in. thanks.
[Re: 0x01b8]
#655986
03/31/10 06:35 PM
03/31/10 06:35 PM
QWK_ENUF
LOWELL IN
this is as close as i recall one dyno has been called happy and the other conservative
car 1
3500 lbs 10.0's @ 134 788 hp
car 2
3000 lbs 10.30 @ 134 620 hp
car 3
2990 lbs 10.96 @ 118 560 hp
WAXER
